werks b6..rebuildable?
Ok so I picked up a used b6 standard for $50. Was Todd its got 1gal on a new pinch and that its having idle problems. When it gets here I will go over it and pray it just needs to be sealed. If that's not the case are rebuild kits available?I haven't been able to find anything on line and am waiting to hear back from Werks racing about it.
Thanks!
Thanks!
Thanks!
Thanks!
Thanks! I'm stoked!
Was the rod changed when it was resized? Best case scenario is it just needs some TLC, worst case everything is showing wear and you start throwing money at it because you can't diagnose one problem.
EDIT: I just looked on A Main... wrist pin is $18? Good god, is that price right?
The wrist pins are gun drilled and hardened. Have you ever heard if anyone with one of our engines needing to replace one??? I've rebuilt an engine 5 times and never needed to replace the wrist pin. An OS carb cost $150, never hear of anyone complaining about that because you never need to replace it.
buy a new motor as back up
Yeah i'm hoping its just needing some tlc and sealing up. If it ends up being a money put then I will junk it.fingers crossed. Still waiting on my used buggy to arrive so I can install it.gotta pick out a pipe for it too.and fly wheel and clutch, and pinion...
I'm on a rather limited budget if you couldn't tell....
how do you seal an engine?
Could have been as simple as a leaky fuel system or exhaust pressure on the persons ride you bought it from. Also possibly a bad pinch or not broken in very well on the new pinch. For $50 bucks it's well worth sealing and testing with a good tank and fuel tubing, or if the compression is gone it is still not a waste to have it pinched again.
