replacing clutch pins
Do you think you can change clutch pins and they will stay in ,reason I ask is cause I got half a dozen reckward clutches the 2.5 type where you can easily change clutches ,and I like the way they work and you can't buy them anymore from a main or anywhere else ..
now I have quite easily hammered and installed a new pin in they are 2.5 thickness same as some of my mugens pins I got floatin about ,I only think i may have to apply some glue before inserting so they stay still ....
Has anyone done this and worked or is it dum idea
Thoughts ?
Thoughts ?
