flywheel collet help
Old 05-12-2012, 09:46 AM
rollagen's Avatar
Default flywheel collet help
A little back story on problem. I recently bought 8t 2.0 its a used so i went through it somewhat. Bolts are all tight grease where it needs to be that sort of stuff. I fired it up on the box and made sure it would run and idle. I hit my local practice track ran about a tank and hald then it made a funny noise like the gears were wearing out. I shut it down and checked it out. The flywheel was free spinning so i pulled it apart to see the collet had a spilt. What would cause this to happen. I have a nitro tc and have never had anything like this happen so im lost. Any advice would be helpful. Thanks.
rollagen is offline
Old 05-12-2012, 11:52 AM
Jerm13's Avatar
Trader Rating: 36 (100%+)
Sounds like the nut holding the flywheel on came loose. When that happens, your crank spins but not the flywheel. if its at all chewed up, I would recomend getting a new collet. You MUST use a Losi collet with a Losi flywheel. They are different in size than the standard 3 shoe ones.
Jerm13 is offline
Old 05-12-2012, 11:56 AM
That's the thing about used stuff..could have been just a matter of how many times the collet has been removed and reinstalled by the previous owner. I personally have never had this happen either...probably just a worn out collet..or a fluke..
*Edit* Ditto on using the Losi collet.
FLDan is offline
Old 05-12-2012, 02:10 PM
rollagen's Avatar
Cool thanks for the help. The nut holding the flywheel on was tight. Its very worn out so ive ordered a collet. How often should these be replaced? Ive ran my nitro tc for over 10 years and never had to replace it so its kinda a weird thing to me.
rollagen is offline
Old 05-12-2012, 02:15 PM
Check your flywheel for wear also.. If they come loose it can also wear the flywheel opening where the collet goes.
nothin special is offline
Old 05-12-2012, 03:53 PM
Trader Rating: 47 (100%+)
+1 to that statement. The flywheel is probably trashed too.
I've seen it happen a few times on those flippin Loosezees.
rageworks is offline
Old 05-12-2012, 08:38 PM
rollagen's Avatar
The flywheel looks good. The collet was just worn out. I ordered the collet. I could order the collet and flywheel assembly. Im replacing everything in the clutch bell to be safe. Thanks for all the help everyone. Much appreciated.
rollagen is offline
