Glow plug heat ranges
No , there isnt really a "baseline" standard as plugs of dfrnt mfgrs are designed so dfrnt , small diameter orifice with ultra thin filament which kinda acts the same as a larger orifice with thicker filament , the mfgrs try to keep plugs in the propr heat range for their respected engines
The 97t is very hot and fragile , easy to tune but doesnt last long and should be replaced often , although steve is coming out with "new" plugs sometime soon
Novas use c5tgc , c6tgc and c7tgc from cool to warm weather
i thought the od 97t was a med heat plug. not hot like 77t.
