Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Old 12-06-2011, 04:01 PM   #1
I Wheelie A LOT's Avatar
Trader Rating: 15 (100%+)
Default WD40 In Carb?
Hey guys, i was wondering if WD40 is okay to spray inside the carb? Is it safe? Can it ruin my engine? I heard people spray WD40 inside the carb to help loosen sticky throttles. Thanks!
RC isn't a hobby, it's an addiction.
Losi 8ight-T 2.0 | HiTec |Picco 5TR| Spektrum |
Mugen MBX6R | Novarossi P5 | Savox |
RC8.2
I Wheelie A LOT is offline   Reply With Quote
Old 12-06-2011, 04:09 PM   #2
Suspended
Trader Rating: 202 (96%+)
its ok to use wd-40 if you are oing to run or re oil the bearings after, wd40 will dry out bearing and seals if left on.
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 12-06-2011, 04:11 PM   #3
stallen50's Avatar
Trader Rating: 30 (100%+)
i wouldnt i would just take the carb off and use some nitro to clean the carb
agama a8 usa edition
Arrow gtr.21, os speed
savox servos
thanks to my 2013 sponsors: vp-pro tires, hobbypro usa, beta tires, arrow racing, team terribles, boca bearings
stallen50 is offline   Reply With Quote
Old 12-06-2011, 04:22 PM   #4
Ok thanks! If i use nitro, do i just let it sit there or would i have to take it out after? Also, is it ok to use nitro cleaner too?
RC8.2
Old 12-06-2011, 05:06 PM   #5
TX_Punisher's Avatar
Just don't use WD-40 on silicon-filled cranks.
XRAY XB9 & XT8 ☆ Airtronics M11X ☆ Novarossi Powered☆ Werks Fuels ☆ Hitec
TX_Punisher is offline   Reply With Quote
Old 12-06-2011, 05:17 PM   #6
stallen50's Avatar
Ok thanks! If i use nitro, do i just let it sit there or would i have to take it out afterAlso, is it ok to use nitro cleaner too?
Pour some nitro down the body of the carb then move the slide back and forth then rinse and repeat. pull back the slide boot and clean that end with a paper towel then pout a lil nitro there and move it back forth until the carb slide moves freely. i have never used nitro cleaner. i think that is for cleaning the outside of engine and car
savox servos
Old 12-06-2011, 05:23 PM   #7
houston's Avatar
Trader Rating: 91 (100%+)
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-06-2011, 05:25 PM   #8
houston's Avatar
you are absolutely correct , nitro cleaner in the can not recommended for engine internals
fuel works great , even better is denatured alcohol i use gallons and gallons of the stuff
Old 12-06-2011, 05:41 PM   #9
Trader Rating: 47 (100%+)
I just soak my carb parts in nitro fuel. For winter storage I
use a good synthetic engine oil that has rust inhibitors in it.
I flush them out with nitro fuel before I run them again.
http://www.amsoil.com/storefront/zrf.aspx
rageworks is offline   Reply With Quote
Old 12-06-2011, 07:24 PM   #10
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
+1 don't use in filled cranks you run the chance of engine damage happened to me
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
RC news in SABAH! jfc_tech Malaysian R/C Racers 5426 01-27-2017 10:21 PM
PRECROTATE ENGINES NOW AVAILABLE IN NORTH AMERICA janderson78 Offroad Nitro Engine Forum 548 12-28-2011 04:47 PM
Which is better: Afterrun oil or WD40? sokar Nitro Off-Road 62 07-27-2009 10:26 AM
After run oil/wd40 supermoto552 Nitro On-Road 13 04-07-2007 01:22 AM
