Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Old 12-01-2011, 12:48 PM   #1
Default Newb engine bearing help?
Hi I am rebuilding my first nitro motor. It a VX .18 and the front and rear bearings are shielded 10x19x5mm. The direct replacement bearings are only available from overseas and cost more than the motor is worth.
Question is, will any shielded radial bearing work or is there a specific rating or type for nitro motors?
I just bought 2 6800ZZ from rc bearings.com, will those work?
Hudsonaj36 is offline   Reply With Quote
Old 12-01-2011, 01:28 PM   #2
Peter Martin's Avatar
If it came with shielded those should be OK. There are different tolerances but for an engine like that I doubt they spec'd something special.
Peter Martin is offline   Reply With Quote
Old 12-01-2011, 02:02 PM   #3
Yeah it's just a cheapo motor.
I always thought the front bearing would be sealed to avoid air leaks but this appears to be shielded as I can see some daylight through it. Is it common for low end motors to have shielded instead of sealed bearings?
Old 12-01-2011, 02:50 PM   #4
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Wow thats asking for problems
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 12-01-2011, 03:13 PM   #5
Normally they are sealed...one seal outside. On Road engines...for years...had no front seals. Not a common practice today.
Old 12-01-2011, 03:19 PM   #6
Cool, unless anyone thinks of a reason not to I am going to put a sealed bearing up front.
Thanks for your help
Old 12-06-2011, 11:14 AM   #7
triplebvalp's Avatar
Don't know what you call expensive:
http://www.avidrc.com/product/8/metr...-bearings.html
Hold my beer and watch this!
Jammin X2 CRT/Nova P5XLT/Werks 2013
HB D8B/Werks B2/Werks 2058
triplebvalp is offline   Reply With Quote
D&M Speedway Topeka Outdoor Off-Road JPMSRacing Kansas/Missouri Racing 5448 10-09-2010 09:01 AM
newB here with a few questions jmartinez1228 Nitro On-Road 6 01-02-2010 08:49 PM
Which one of these 2 r/c's should i get? Zeeshan Rookie Zone 36 03-17-2009 09:08 PM
Deciding between 3 R/C's, some help please? Zeeshan Nitro Off-Road 34 02-12-2009 09:04 PM
