Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Old 11-25-2011, 02:57 PM   #1
vito's Avatar
Default help slipping one way
i have a os cvr 18 with a slippinr one way how do i fix it?
vito is offline   Reply With Quote
Old 11-25-2011, 08:30 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Take it apart and clean it. If that does not work you need a new one way bearing and also a new shaft that inserts into it. The metal will grind itself and cause the two pieces to slip instead of grab.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 11-25-2011, 08:35 PM   #3
stallen50's Avatar
Trader Rating: 30 (100%+)
take the bearing out and use some carb cleaner to clean it out
agama a8 usa edition
Arrow gtr.21, os speed
savox servos
thanks to my 2013 sponsors: vp-pro tires, hobbypro usa, beta tires, arrow racing, team terribles, boca bearings
stallen50 is offline   Reply With Quote
Old 11-25-2011, 09:16 PM   #4
motomatt's Avatar
Does it have a pullstart? If so pull the starter handle out slightly and spray nitro cleaner into the housing next to the starter rope.
Do you use Blue Thunder fuel?
motomatt is offline   Reply With Quote
Old 11-26-2011, 11:17 AM   #5
vito's Avatar
thank you i hit it with brake cleaner and it works now
Old 11-27-2011, 11:45 AM   #6
vito's Avatar
i have to get a new one now. so i got a pull start and one what do i all need?
Pull-Start One-Way Bearing Not Catching big420dog Nitro On-Road 7 01-04-2009 06:14 PM
One-way diff slipping........HELP!!! Tpg racer Electric On-Road 26 05-12-2007 08:10 AM
Ball Diff, One Way, Spool tr1kstanc3 Rookie Zone 9 10-06-2005 07:53 AM
