Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Old 11-24-2011, 07:01 PM   #1
traxxas-owns's Avatar
Default Burning Up Glowplugs
My brother has a traxxas t-maxx and he started having the problem of burning up glow plugs. I have looked at it and tuned the carburator for him, but can't figure out why he has burned up 3 already. The glow plugs aren't defective because this has happened 3 times within 1 week. I make sure the engine runs super rich so it's not that it's too lean, any ideas will be appreciated.
Traxxas Bandit, Flysky
traxxas-owns is offline   Reply With Quote
Old 11-24-2011, 07:15 PM   #2
Trader Rating: 20 (100%+)
In my experience it's rod bushings that cause issues with plugs
Matt Piva is offline   Reply With Quote
Old 11-24-2011, 07:18 PM   #3
I am sort of new to rc, what is the rod bushing?
Old 11-24-2011, 07:57 PM   #4
It's the brass bushing between the rod n crank pin (that didn't make it any easier for u lol) anyways it make b blown n causing lil pieces to chew up the plugs. Whenever I blow a plug I use an old plug out of another good engine thats still strong to replace n try out incase I have a bushing that goes, it usually doesn't take long to blow again n if it does u no it's that, but if ur blowing plugs like 1 time a day n running alot then it's tune cause a rod won't last long it just tears up the plug.
Old 11-24-2011, 08:11 PM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
Can you post a pic of what the plug on the coil side looks like. Plugs usually blow due to bad tuning when they go fast. An engine that is too rich will pop plugs too
Old 11-24-2011, 08:59 PM   #6
hdcruzer's Avatar
Yep what frank said too rich an engine will blow plugs too.
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 11-25-2011, 07:04 AM   #7
Lille-bror's Avatar
Dirt through the engine.
Defective ball bearings.
If the crankshaft isn't draged all the way to the front of the engine, before the flywheel were mounted, the crankshaft will scratch on the backplate and send metal parts through the engine.
www.xray-shop.dk www.northtq.com
Best regards Bjarne Petersson, Denmark
XRAY / FX Racing Engines / OS Speed / HPI / Byron / HUDY / Proline / Sanwa MT4s / Sav÷x servos / Ultimate
I miss you Amy...
Lille-bror is offline   Reply With Quote
Old 11-25-2011, 04:29 PM   #8
Can anyone post schematics of the engine with the bushings pointed out so I know what to look at?
Old 11-26-2011, 01:32 PM   #9
8T
8T's Avatar
Also check the top of the piston for to much carbon build-up. That could cause blown plugs too! If there's a lot of carbon, clean the top of the piston and the head with some 0000 steel wool.
8T is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15109 10-10-2017 04:01 PM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
