Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Old 11-24-2011, 09:49 PM   #61
jmaxey51's Avatar
Originally Posted by doug e fresh View Post
I'm really torn in between the two. There are vids of the .21 but I can't fine any of this .23. Anyone know where I can find a vid??
Also the 21 is more $$ money than the 23 does that matter?? I know my money is going toward one of the engines.. Thanks all and if you can find a vid that would be awsome!!
im pretty sure he is running a 23 in this one: http://www.youtube.com/watch?v=oj7O9YArYtg
IMO, for SC8 i would go with the 23 for the little more low end grunt, the top is about the same, the 23 may have more.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 11-24-2011, 10:03 PM   #62
I think if the .23 is cheaper, it's a no-brainer. Get it. You could even run an 18T clutch bell. It will be very, very fast.
Just do a good break-in. Wrap head in alu foil, prop a hair-drier at a slight angle for ten minutes or so on top of the head, so that it gets up to about 200F. You're gonna' need to do that for the first gallon or so, before every start..
-Team Associated RC8.2, RC8T CE, & SC8 with 1.) Argus A52/0801, 2.) RB Fire 11/2058 or 053, 3.) RB Blast V9/2045, 4.) Nosram RS.30RR/JP-4, & 5.) modded Nosram RS.21RR/086
-LST2 #1 with Losi 454 & LST2 #2 with Dynamite Big Red .28
-Ofna DM-1 with silver Mach 427/2047
-TT MT4 G3
Herrsavage is offline   Reply With Quote
Old 11-25-2011, 07:34 AM   #63
jmaxey51's Avatar
you will need to heat each side of the block to put less strain on the engine/rod... i would do this with any engine.
Old 11-25-2011, 08:13 AM   #64
+1.
Get a cheapo heat gun also, a lot faster than a hair dryer.
TPJ International
071crazy is offline   Reply With Quote
Old 11-25-2011, 10:00 AM   #65
Ambros303's Avatar
Metal is a very good heat conductor...
After 10 mins that case will be heat soaked on all sides. Look at the dedicated engine heaters...they heat up the coolinghead...but the piston and sleeve are not at the head, they sit substantially lower in the case. The heat still travels to the case tho because metal conducts heat so well
Kyosho ST-RR Evo-ed // Sirio // Hitec // Sanwa
Kyosho MP9 TKI2 WC // Sirio // Savox // Sanwa
Ambros303 is offline   Reply With Quote
Old 11-25-2011, 11:42 AM   #66
I didn't mean heat the head from the side. I just meant put it at a slight angle so the hairdrier doesn't fry - so the heat goes down to the plug, but if it's at a slight angle the air can get out too.. I wrap the head in alu foil, and prop the drier on top of the head.. After ten minutes or so I've had a temp-read of 280..(OK, maybe 15 minutes.. Still, prob wasn't so hot down in the case..), but normally it'll be around 200ish..
-TT MT4 G3
Old 11-27-2011, 03:44 PM   #67
doug e fresh's Avatar
Thumbs up
Hey guys!!
So I'm going to place my order for one of the two alphas. Either the 21 or 23, don't know what one. I know its a alpha but what one??
Forgot to add I'll be placing my order Wed!!
Losi comp crawler, proline 72 Chevy body.
Sc8, AKA impact, Tbone raceing, kings heads, snr shock towers, novarossi .28 7t..
Hpi savage xs flux, stock besides rpm revolver rims and proline road rages..
doug e fresh is offline   Reply With Quote
Old 11-27-2011, 04:19 PM   #68
jmaxey51's Avatar
Hey guys!!
for the SC8, i would go for the 23. but either one will be fine. the 23 makes some power, its a blend of a 21 and 28. you can get more feedback and help on the Alpha topic if you'd like even more info.
Old 11-28-2011, 08:58 AM   #69
If you go with Alpha : S852 / A532 / A352 coupled with a 2081
Also a very good engine, Werks B5 with a 2013/2058, that will rip youre SC8
Aleq is offline   Reply With Quote
Old 11-28-2011, 09:55 AM   #70
I posted my video of my Sc8 with an Argus (SC8), running a 17T CB. I bet, with the Alpha .23(which btw is supposed to rev nicely...), you could run an 18T CB and be even faster..
If I didn't already have too many engines, the Alpha .23 would be very much at the top of my list for the SC8... But then again the A852 is meant to be a monster...
Man.. See?.. All good.. Argus, Alpha A852 or S852 or .23... All good..
-TT MT4 G3
Old 11-28-2011, 10:13 AM   #71
Questions??
Hey guys!!
Ok so I could very easily order a alpha on line but I'm trying to support my locial hobby shop. It's a mom and pop store.
I called and tried to see if he had an alpha .21 or 23. He had neither but he does have an Orion .21 and he said its an alpha based motor. Do you guys know anything about orion?? If you do could you please give me some feed back on what you guys think.. thanks all.
Old 11-28-2011, 10:19 AM   #72
stallen50's Avatar
Trader Rating: 30 (100%+)
it is not alpha based. they are good motors maded by LM which makes werks too. i had ok luck with them.
agama a8 usa edition
Arrow gtr.21, os speed
savox servos
thanks to my 2013 sponsors: vp-pro tires, hobbypro usa, beta tires, arrow racing, team terribles, boca bearings
stallen50 is offline   Reply With Quote
Old 11-28-2011, 10:20 AM   #73
stallen50's Avatar
its alpha line for orion.
savox servos
Old 11-28-2011, 10:25 AM   #74
stallen50's Avatar
http://www.amainhobbies.com/product_...ine-Turbo-Plug or the 5port too. i have had good luck with them so far.check em out
savox servos
Old 11-29-2011, 02:13 PM   #75
Thumbs up
Hey guys!!
So here's my engine.
http://www.amainhobbies.com/product_...ht-Weight-Head
I'm trying to support my local hobby shop and his supplier has that engine in stock so I'm going to put a down payment on it tomorrow. What do you guys think??
What Engine is Best? .21 for Buggy Victory Side Nitro Off-Road 45 03-25-2009 05:44 PM
best 21 for the buck musti72 Onroad Nitro Engine Zone 10 01-19-2008 11:05 AM
Best .21 for under $200? Aflem Electric Off-Road 7 01-21-2007 03:50 PM
