Using engine heater after break-in?
The title essentially says it all. I know that using an engine heater is an absolute "must" when breaking in your nitro engine. However, do you continue to use it even after break-in? Like, your first engine start of the day on race day? Let the debate begin!
Yes I use my competion heater alot. I use it for the first start up, when it's cool in the morning and when it's on the cool side through out the day. My engine fires up easier and basically sits there and idles nice.
*nod* Makes sense. I am thinking that a warm start-up at the beginning of the day must be gentler on your engine internals too. I am definitely all about getting the most mileage out of my engine.
Definitely got my eye on one of those 12v Competition Heat deuce heaters for next year.
For me I don't see any point after a motor hits its prime 2-3 gallons. I always heat my engine on break-in to the 2 gallon'ish mark then my Rod gets changed all my motors last super long well past the 8 gallon mark no issues.
The life will be lengthen a lot when using pre-heating. Not only the P/S set will gain a lifespan but also the bearings.
The cold start and giving some throttle is giving a lot of heat into the piston because it is a small thing while the sleeve is cooled by the crankcase and head taking a while to warm up. The piston will scratch in the sleeve.
Oh you big jerk!
I am envious of places that get to race year-round. Here in Canada, the season ends pretty abruptly in late fall, due to rapidly plummeting temps. And sadly, my city is not lucky enough to have an indoor offroad track. *pouts*
I don't really think there is a debate here.
It's really not that hard to preheat the engine every time you fire it up, and it will only extend the engines life. Plus it heats everything up, even the chassis (if it's on long enough) which will mean it will be pretty close to race temps and tune the minute you fire it up, instead of having to do warm up laps and wait for it get up to temp before tuning. Definitely a must when it starts getting coler out, or when your running at 2 in the morning!
Ditto for me. I pre-heat my 7 gallon old Alpha when I run it still ;-) All my engines get warmed up before I fire em up...mainly for the reason PERROTTO stated above...after they "break in" I use it to get the engine ready to race instead of blubbering cold for the first few laps....
Preheat before fire it up? Just turn the engine 5 minutes on the starterbox. Then its pretty warm and ready for the glowheater!!!!
What do you gain by pre heating? More usable run time on your engine. The time you would spend starting and revving to generate enough heat to tune it for the air conditions is just wasting the engines life, not to mention the fuel burned. Most of us race on a budget, its a hobby, if you can increase your engines life, save on fuel, glow plugs, time, ease of tuning etc. The question is, why wouldn't you.
