Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Old 10-06-2011, 07:01 PM   #1
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Default Pipe EFRA Question
Was wondering if all pipes with the same EFRA are =. Example the OS 2090 pipe and Alpha 2090 Pipe will the inner dimensions and performance be similar/ same.
If you look at the pipes they look different
http://www.neobuggy.net/modules/news...?storyid=10173
http://www3.towerhobbies.com/cgi-bin...&I=LXBHUA&P=SM
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 10-06-2011, 07:03 PM   #2
Trader Rating: 39 (100%+)
From what I remember, OS's pipe numbers are not the EFRA numbers. For instance, the 2060 is actually EFRA2042.
But usually for other companies, the pipes would otherwise be identical. Like the Ofna 086, Dynamite 086 or Novarossi 9886. All the same.
BrakeTurnAccelerate is offline   Reply With Quote
Old 10-06-2011, 07:05 PM   #3
RC Pro 1's Avatar
Zoom in on the OS2090SC pipe and it appears the EFRA # is 2089, the number to the right of the big 2090 number. The 2090 designation is the OS part number not the EFRA number. These pipes are not the same as the Alpha where 2090 is the EFRA number.
RC Pro Products - Alpha Plus importer for North America
RC Pro Products, Alpha Plus Engines, A Plus Pipes, Voodoo Nitro Fuel & Glow Plugs.
RC Pro 1 is offline   Reply With Quote
Old 10-06-2011, 08:38 PM   #4
bigjayjay1's Avatar
Thanks I missed that one I have many 2060 and Mugen EFRA 2042 - same pipe didn't click.
The alpha pipe looks interesting was hoping they were the same due to cost looks like I have to spend the $$$.
Do you know if this pipe is a low or high end pipe seems to be a low-end pipe from its size and width.
Old 10-07-2011, 12:52 AM   #5
Roelof's Avatar
Send a message via ICQ to Roelof
The outside looks does not tell anything about the internal configuration. I know there are pipes looking the same on the outside but a different inside tuned to the specification.
Normally all different brands using the same EFRA number must be the same pipe because the EFRA number is an homologation number so the product can/may not be different than the homologated original.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Tune pipe comparison losi_alaska Nitro Off-Road 15 10-27-2009 09:06 PM
pipe for a jx-21 sideways88 Nitro Off-Road 24 10-22-2008 09:45 PM
The JP-3 pipe question offr0aden Nitro Off-Road 20 10-06-2008 07:23 PM
