Odonnell 97T Plugs
Odonnell 97T Plugs
Ive been running these plugs for over 2 yrs and never had a problem. The last card of 6 I bought Ive used 2 of them and they just crap out for no apparent reason. They will run for a tank or 2 and start to flame every time I punch it, then they will just work with ignitor on and the minute you take it off it will die. Any body else been having this problem with the Odonnells. I read awhile back there was a bad batch or somthing. Ive even put a older one in from a different batch and not a problem at all.
I just had to replace a p/s in a friends Alpha green head engine
because of an OD97 glowplug. He hadn't finished the first tank
of fuel on the new plug, when the plugs coil dropped out and
tore the piston and cylinder up. I replaced the Alpha 5 port
sleeve with a GO 7 port sleeve. So, we now call it a "Gopha 7"
engine. I just finished breaking it in today. It turned out to be
a sweet little engine.
i had ran these on and off for couple of years with no real issues....i mean i found that they didnt last as long as the os p3 or p4's but for the price i liked the 97t's.....just bought 40 of them here on tech and ran them in my speed motors and been having tuning issues.....put a new plug in ran a tank and then pulled it out and first 2 bottom coils werent burning and put another in and same thing........not sure what the deal is either but it has me wondering....
I just started breaking in an Argus with a 97T, and have had weird issues. Mostly the engine shutting down after I take the ignitor off. Might be just a rich tune, but it seems weird.. Anyway, need new plugs, so was thinking of getting some Go T3's and T4's.. Are these similar to the Odonnells?
try a werks #6.....very durable, crisp running plug that lasts a very long time...Works good in Alpha's,Nova's,RB's,Picco,Werk's,Techno's etc....not uncommon for us to get 2 gallons from these plugs, and to date have never had a coil break.....
Unfortunately there are no Werks plugs in Europe that I know of, let alone Germany.. I need something local, and that means OS, Go, NR, or RB. Orion too. Which actually are probably pretty similar to Werks(if not identical).., both being Sirio-based.
http://www.jvd-rc.com/catalog/glow-plugs-47/
He will most likely ship to Germany.
The Orion plugs are excelent aswell and as you say most likely the same as the Werks plugs (-both LM)
