my engine stops when the buggy is upside down
Hi there I have an OS engine on my 1/8 buggy, I use a d8 fuel tank.
When I flip over and my buggy is upside down, if I have run more that half of the fuel on the tank the engine stalls after 5 seconds.
It seems it is running out of fuel. There is a clunk on the tank in order to overcome this problem, but unfortunatelly it is working only if the tank is 50% -100% full of fuel, from 0% - 50% the clunk is not working.
Do you have any advice about that ?
yup replace the fuel line in the tank and make sure the clunk is able to "clunk" hold car up side down and see if the clunk falls to the bottom or not...
I have replace it, and it is working fine when i turn it upside down.
The problem from what i imagine is that when the buggy is upside down the rear of the car is higher than the front hence the fuel goes at the front side of the tank which cause the clunk to fail and stall the engine.
well the 100% solution dont flip over when the tank is half empty lol I dont know what else to tell ya I have never had this issue with my D8
+1....When your Low speed needle is set a little too lean cars will not idle long when upside down. Like the other poster said, try richening the LSN a bit. Fill the tank half full and just flip it upside down ans see if it helps.
Lance
RcRenew.com
Lance
RcRenew.com
I noticed as well dust behind the flywheel and arround the front bearing of the engine, do you think there is a leak from the bearing. Is it normal to have dust at that side of the engine?
Thanks.
Also u need to check for exhaust leaks at header to motor and header to pipe when tank is 50 percent or less if have exhaust leak when car is upside down will not have enough fuel pressure
I have tried your recomendation with no luck.
The ambient temp today was 95-100 degrees, 50% hunidity.
I have richen the LSN Half a turn. Now it 6 turns from fully closed. The HSN is on 2 turns from fully closed.
On the starter box the engine was feeling ok, but when I was hitting the track in the first straight the car was accelarating with too much smoke a bit fat from low to medium rpm but from medium to high rpm the engine stalled.
I leaned the HSN to 2 turns from closed.
The engine produced a lot of power aroung the track with maximum temp 250 degrees. The problem of stalling while upside down & half tank full was still there. I have checked for leaks but there is nothing on the exchast, that seem to leak.
I believe it is my tune...it seems difficult to tune the engine in such weather conditions.
Can you give me some tips, a video maybe...
I there any solution to this problem ?
