replacing thermo insulator on O.S. 21J carb
has anyone ever replaced the thermal insulator that goes around the outside of the carb where it meets the motor on O.S. carbs? you can purchace the part seperate from the carb, but i just wanted to know what it took to install it.
thanks .
thanks .
what he said^^^^^ very easy.
You definitely don't want to glob the stuff on there, only to have it mush out and mess up the o-ring surface when you slide the new insulator on.
Don't give it too much worry. To be honest, cutting the old one off, and actually mixing the epoxy are the two most laborious parts of the job.
ive used 2 part jb weld.
