Nitro Engine too Hot?
Curious.Im pretty new to nitro.When running my eight buggy, before the tank runs out of fuel the acceleration gets more and more sluggish until finally it wont accelerate at all.Just idle.Then it will die.Ive checked the engine temps and they are 290 degrees.Could I be running too lean and is that causing the problems?
R/C Tech Elite Member
http://www.rctech.net/forum/offroad-...ing-bible.html
Im no super tuner but 290 is HOT. If your no pro and need every drop of power, you shouldnt run at 290 - richen up to prolong your engine life. If you go $$$ to blow then whatever.
i had a picco .26 outlaw that was a absolute animal hovering around 300 degrees. But every other engine i have had 260 has usually been the limit after that you are not really gaining anything.
What kind of fuel are you using?
The Engine is a SH .21. Fuel is Trinity 20%
I leaned it out yesterday a little and the temp went down to 257.It finished the tank without loss of power.You guys are smart! If I lean out the low end needle will I get more torque off the start?Will the temps go up again?
Sounds lik your plenty lean. But the only real way to tell if you want lean 30 minutes at a time until performance decreases. If you have to close your idle to paper thin to get a steady idle you are pretty much to lean.
Gotta have good SMOKE
if your engine is idling good at 290.. then your tune is out of wack.. or you got a leak somewhere in your fuel system or engine... which will have your tune out of wack to compensate.... i've reach 290 before... and the engine seemed to be running fine.. the engine was doing double duty that day.. so ihad to take it out and put it in the truggy.. and i had to tally retune... and it ran at 230... and just screaming... changed the tank... and walla in the buggy it ran at 210.. so just changing the tank give me a temp drop of 80 degrees .. just some points you should consider..
ps.. im glad i was able to figure that out.. cause i dont think my bearings would of lasted a 30 minute main at 290...
