B6 on MBX6 clutch setup
New to offroad and I have an MBX6. I have a B6 installed and wanted to know what a good clutch setup is or if mine makes sense. The kit has a .5mm washer to go between the collet and front bearing. I didn't install the .5 washer between the front bearing and collet(using the collar that came with engine, not the one from kit). I assumed I need to make up the .5mm by shimming out the CB. I installed a .1 shim between the flywheel nut and inner CB bearing. I put five .1mm shims on the end of the bell. I have .7mm gap to the end washer. I was wondering what other guys run. A friend told me anything under 1mm should be ok but wanted to ask. Also, using the buttonhead screw from kit for the crankshaft after reading that there could be clearance issues between crank and fuel tank on the MBX6.
