Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Old 03-24-2011, 01:04 PM   #1
DiZzYNaTiOn's Avatar
Trader Rating: 25 (100%+)
Default Odonnells .21 SS Engine Mods?
After reading the Super Charger thread, i was wondering on how to mod the Odonnells .21 SS, I am hands on guy and as long as there is no machining involved i can do it myself, any ideas, what has been done to this engine before.
www.filmmakerforum.org
RC8B3 - OS Speed .19 - S9352HV - 4PKS
DiZzYNaTiOn is offline   Reply With Quote
Old 03-24-2011, 01:09 PM   #2
Stubbs's Avatar
Trader Rating: 57 (100%+)
PM Neal from Clockworks (Maximo on RCTech). He's modified an SS.21 previously.
Also, one of the other team drivers was running a Murnan modified SS.21 with good results.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 03-24-2011, 01:12 PM   #3
jmaxey51's Avatar
from what i understood from modders, the SS is a tricky engine to mod, the timing or something is a little different than most and can be messed up easily ... i think i heard this from maximo, but i cannot remember ...
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 03-24-2011, 01:30 PM   #4
kaptain crash's Avatar
Trader Rating: 33 (100%+)
Send a message via Yahoo to kaptain crash
One of the best mod's you could do to that motor is lighten up the head...it's heavy. Stock weight is 113g, some drilled hole's in them 102g, I dremeled mine for two reason's to lighten and I hate ball driver's, 86g. Stock v-spec 91g
YEAH IM OLD...RUSTY AND SLOW,CRASH A LOT TOO. BUT WITH NITRO I HAVE A BLAST!
kaptain crash is online now   Reply With Quote
Old 03-24-2011, 01:41 PM   #5
nitroexpress's Avatar
For the most part, modding an engine is not a do it yourself project. You'll have to send it out and expect to pay $85 - $100
nitroexpress is offline   Reply With Quote
Old 03-24-2011, 04:12 PM   #6
AAHHH thats a good idea, never thought of that, so at the end of you comment are you saying to just buy a v-spec head or dremmil it?
**EDIT** Just to let you know i am not going to do iether, ill just leave it stock, plenty of power for my buggy but was just curious...
Old 03-24-2011, 06:37 PM   #7
Naaaa I just dremeled the SS head, now it weighs 86 grams, and can get a regular driver in the motor mounts now also.
Old 03-24-2011, 07:07 PM   #8
Does anyone know if there is a way to turn the part of the carb where the high speed needle is? I would like to angle mine more forward so it fits under the body better on my buggy.
Old 03-24-2011, 07:19 PM   #9
j_blaze14's Avatar
Trader Rating: 34 (100%+)
nope, gotta cut a hole in the body for the screw driver... or try an older sirio/orion carb.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 03-25-2011, 12:56 AM   #10
Roelof's Avatar
Send a message via ICQ to Roelof
I disagree with you. Look arround on the net and you will find lots of do it yourself articles about porting an engine. Porting will not gain power but it makes the engine better in idle, spinning up and can give it slightly more RPM.
Also a tiny small change on the cranktiming can do a noticeabel increase of performance.
Raising the sleeve with modded headshims does change intake and exhaust timings, it is a thing anyone can try and it can also be undone.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 03-25-2011, 05:41 AM   #11
I find it interesting that every engine modder claims to be able to achieve more power and in some cases, more mileage. So if I mod my RB C6, I can make it a better engine than Rody designed? If modding was so across the board good, that would seem to indicate that people who make a living designing engines may not know what their doing? Just saying.
Fanging and turbo cuts really don't help that much. I would think the changing of crank and port timing would be too much for most people. Takes the right tools and experience to beat Rody at his game.
Old 03-25-2011, 05:58 AM   #12
+1 seems like everyone with a dremel is a modder.
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 03-25-2011, 06:40 AM   #13
Roelof's Avatar
And you do realy think your standard consumer engine is already set to its maximum?
Fuel milage is always a tricky thing, most of the times it comes from the moment you have to go really easy on the throttle and a change in timing can make the efficiency better but also worse. Some basics of modding will always work, going to the limit is more about trial and error and from what I have seen small changes up to 3 degree in timing does change an engine noticeable without hurting other aspects.
"Flowing" does not improve the real performance but you will notice the more steady idle and the faster spin up, only that can already give a more satisfied feeling about the engine. Indeed a change in timings can do much more.
Anyone who can handle a dremel can do some porting and a small change crank timing by a tutorial. Messuring and so listing of the timings so you can re produce your modding is something different but still easy to do with simple tools.
And wanting/daring to give it a try is up to you, if you have some old engines you are not going to use anymore then the barrier is not that high to give it a simple try.
Here is a nice list:
http://www.first-racing.eu/html/steuerzeiten.html
You can see some engines in standard and modded shape so you have an idea about how much is possible (and these numbers are no limits)
Old 03-25-2011, 10:40 AM   #14
So anyone with a dremel can improve a Rody Roem or O.S. Speed engine?
Many modders state that their porting is not visible with the eye. This is probably true because the port and crank timing changes are minuscule. Probably too minuscule for Mr. Joe Average. The changes that the modders are doing can easily be incorporated into any engines original design. A milling machine can easily be programmed to cut the ports and crank into any timing configuration. I know that there are dyno graphs showing the wondrous effects of these self taught modders. But the question remains, why are these modder timings not in the original design?
Old 03-25-2011, 11:11 AM   #15
Roelof's Avatar
Interesting question with some answers I can think of
- you do not want to set the fastest engines on the consumer market, as a manufacturer you want to keep THE RIGHT timings only for yourself.
- The given timings will give you a durable engine to keep the warranty handeling low.
- The selected timings will give a good driveabillity and an easy tuning and so less aftermarket support.
- The manufacturer can set different engines on the market, to give the consumer a choice in budget and performance (mostly it comes togeather with the number of ports).
