A couple question about JL .21
hey guys. my friend just got himself a nice new JL .21 for his D8. he is wondering what glow plugs guys are using in this motor. also is any break in shim used/ required for this motor?
thanks for your help!
thank you very much for the quick answer
I can tell you the 2042 pipe works killer on my X1-v2 and I run our Med and Hot plugs with good results. I'm trying to get this pipe from Hong Nor soon I beleive it's the 2047 but I want to have them in Hard Coated.
I run HPI Pro engine (same as yours and RB killer). Stock shim (still VERY good compression after 7 liters of fuel), 20% nitro, O'Donnell 77t plug (perhaps 97T for more nitro), 6 mm Novarossi venturi. Used the Break-in bible.
My favorite pipe is Novarossi 9901 (efra legal) and JP-3. Very similar in performance and great runtime. I WONT recommend HN 2047. That pipe doesn't do anything good for the engine and the runtime are HORRIBLE!!!! I had to lean the HSN 1/3 of a turn, when I put the 9901 pipe on the engine, after running the HN 2047...
I'm using the losi RE10 on mine with a fioroni T5 plug.I get anywhere from 10:30 to almost 12 min runtime in buggy depending on the track.I do not recommend removing A shim.When I did it my engine started to predetonate and luckily I caught it in time before it ruined it.Some people have had good luck with it but to me the slight performance increase is not worth the risk.These engines last a long time if properly maintained.I've had mine for over a year and still going strong.
I moved the original thread about this engine back up
to page one, so you guys can find it.
As far as glowplugs. I've found that the Ofna T-series
glowplugs to be the best, longest lasting glowplugs
in my Clocked JL .21.
http://www.rctech.net/forum/offroad-...rce-21-jl.html
