What makes 1 engine have better mileage than another?
#16
Tune for performance not temp. If you are getting your best performance and your temps below 200*F. Which happens a bit if you run in colder temperatures. Put a little tin foil over the cooling head a little at a time until temperatures reach over 200F. This technique can help with break in on motors as well.
#17
The way the crank shaft is cut to atomize the fuel and what pipe is used. With the same driver on the same track and truck/buggy with the same tires ETC, only changing the 2 things mentioned up top underlined, you can see 1-2-3/4 to 3 min longer run time. EDIT: tuning accordingly as well.
#18
@NitroXray80809
I see you have a MBX6, do you steel have the black insert in the fueltank if so remove it.
As for the os2060 on your engine, i liked it alot wen i was given a Alpha F850 to test it out.
Fuel mileage and overall performance was very good with that pipe, pitted at 10 min in the one race i used the engine in a MBX6T.
#19
#20
I am not sure about that one...the fuel is atomized as it leaves the venturi of the carb...any contact that mixture has after that actually causes separation of the mixture...I don't believe a crankshaft will atomize the mixture...more like a properly cut crankshaft will offer the least amount of contact with the mixture as possible and cause the least amount of separation possible.....
That's how I should have worded it. I just figured most would know the difference in a factory mass produced crank V.S. a nice cut moded one. I run a moded speed and the difference in milage is huge.
#21
R/C Tech Elite Member
Throtle EPA
I can't believe that no one has made mention of adjusting throttle EPA. I run mine at 75% on a large track and I get plenty of power and just over 12 minutes a tank on my B5/2013 combo in my 6T.
Once you have your tune dialed in, adjust your EPA's for that extra bit of run time. Most people completely overlook this!
#22
personally I don't mess much with crank shape on the counterweight...it causes too much vibrations......if anything I add weight to the counterweight if the engine isn't already slugged...
IMO head button can make a huge difference on mileage... Carb design is also huge......transfer port orientation is also a big factor when it comes to mileage...The engines we do here at Clockwork almost look 100% stock from a visual inspection, but they get substantially better mileage then stock and also make substantially more power.....
#23
#24
#25
button on my radio set up for dual rate throttle EPA's.
I can press the button for full throttle, if I want it.
#26
I think the problem here is completely tune related.
#27
@NitroXray80809
