Cluth bell problem
Old 01-08-2011, 06:14 PM
tq_racing's Avatar
Trader Rating: 67 (97%+)
Default Cluth bell problem
So i am running the losi clutch set up. i have all the losi parts (fly wheel, shoes, clutch bell, bearings, hardwear) i go to put the clutch bell on and tighten it down then it wont speen freely and it backs the screw out.
How do i fix this? my brothers losi doesnt do this and it has the same set up as mine. im stumped here
tq_racing is offline
Old 01-08-2011, 06:19 PM
Suspended
Trader Rating: 202 (96%+)
you need to add 2 or 3 shims before you slide clutchbell and bearings on, if still wont spin free just add shims untill it spins free when screw is tight.
inferno13 is offline
Old 01-08-2011, 06:22 PM
tq_racing's Avatar
i did that and it still wasnt going. ill buy some other shims tho. these were old ones but it still should of worked
Old 01-08-2011, 06:25 PM
Suspended
are you useing the screw and washer from losi? make sure the washer still has the spacer block on the clutch side. after sliding the clutch and bearing on the crank, the crank should be in set about 2mm or so from the front bearing.
Old 01-08-2011, 06:27 PM
2fst2c's Avatar
Trader Rating: 114 (100%+)
Are you using the Losi Collet for the Flywheel? I found out you can't use a normal collet.
2fst2c is offline
Old 01-08-2011, 06:30 PM
Suspended
+1, any other collet will be to big, but did notice you said you have all losi hardware, maybe post pic. might be able to help bit more
Old 01-08-2011, 06:33 PM
tq_racing's Avatar
yes it is. i am not using the losi collet. i have tried 3 different ones but i guess none was losi. ill try that tomorrow.
so off from the motor this is what it should look like.
collet, flywheel (with clutch nut holding it on), shim, big bearing, clutch bell with little bearing in it, the plastic spacer that the screw goes in, then the screw.
Old 01-08-2011, 06:40 PM
gabor szilagyi's Avatar
You can use one or two of this washer under the nut.I think the size of the washer is 3.25mm x5mm
gabor szilagyi is offline
Old 01-08-2011, 06:43 PM
Suspended
yep, you have to use the losi collet with losi flywheel, you will be good to go!
Old 01-08-2011, 06:47 PM
2fst2c's Avatar
Been there, done that! I tried like 6 different ones before I found out they use a special collet.
2fst2c is offline
Old 01-08-2011, 06:48 PM
tq_racing's Avatar
ok. ill post tomorrow if it doesnt work
Old 01-08-2011, 06:50 PM
Suspended
LOL.....have you been running at PG, hows the nitro series going?
Old 01-08-2011, 06:54 PM
hdcruzer's Avatar
If you use that washer it is to space the flywheel out. You dont put it behind the nut. You put it on first then the collet and then the flywheel and then the nut.
hdcruzer is offline
Old 01-08-2011, 07:08 PM
2fst2c's Avatar
No series going on yet. Just Nitro practices. Got a Series starting Feb 5. Check out the nitro thread if you haven't seen it already.
That actually looks to small to be a collet spacer. Looks more like the spacers for the bearings.
2fst2c is offline
Old 01-08-2011, 07:17 PM
Sorry i meant to say behind the screw or behind the outer washer....
