U shaped header VS. L shaped header?
#16
I haven't tried header wrap on these engines as they are so small but what I have tried and worked out nicely was ceramic coating and jethot. The problem is unless you get a big order together, most people won't try the coating because of the price so I haven't bothered getting it done. Most people don't like paying the extra $15 for hard coating let alone paying for ceramic. We coated alot of our trail pipes on our sleds and it worked like header wrap and also looked very nice in the chassis. You could also polish the ceramic to give it a nice shine. I have a local company that could do either ceramic or jethot type coatings but you need like 20-30 sets at a time to make it worth doing. Not too much call for it and I don't have 20-30 sets I want to invest in getting it done only to sit on them if most people could care less about the coating process.
#17
?????? why do almost all off-road engines come with an "L" shaped header then????? nova, rb, tecnopower, or most italin based motors.....
here is a link for 2 stroke motorcycle exhaust but the theory is the same..
http://www.prestwich.ndirect.co.uk/tunedpipetheory2.htm jeremy
"U" shaped
"L" shaped
Notice the orientation of the motor.
#18
I don't understand what you mean, a "U" ahape is what is on all offf road buggies and truggies, the "L" is what is used in on road because the engine in facing the center of the car so the "U" shaped one will make the pipe paint to the other side and not to the front, having the "L" shaped one in an offroad car will make the pipe stick out to the side an a 90 degree angle to the side of the chassis.
"U" shaped
"L" shaped
"U" shaped
"L" shaped
#19
The "L" shaped headers he's talking about are like the one below.
http://www.amainhobbies.com/product_...-Road-Manifold
Notice the double bend [ shape.
The "U" shaped header would be like this one.
Notice the smooth ( shape.
That's what he means by U or L shaped headers.
#20
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
thanks guys.. jeremy
#21
#23
The ] shaped manifold will restrict gas flow but will not affect the back pressure, back pressure is altered at the outlet.
Also the ] shape will not affect the sonic wave in any way, sonic waves carry no mass.
The manifold should be as free flowing as possible as this is the area where gas speed is at its highest. Tuning should be altered by length and not by adding restriction.
#24
#25
Which is why we include a pipe extender (spacer) with our 2057 pipe set and use a smooth U bend manifold A lot of what we discus on here is done in for lack of better words "layman's terms", having an in depth technical discussion about pipe design, harmonics/exhaust pulse timing etc. etc. is going to fly over all but a few peoples heads And you are correct in your statement that a ] shaped manifold will not affect sonic waves in any way, but the sharp 90 degree bend or in the case of that manifold design 2x sharp 90 degree bends will disrupt or have a negative effect of gas flow and gas flow does have mass. So in essence it will create two additional points of turbulence disrupting gas flow which will affect performance of the overall exhaust system because as I'm sure you know entering the manifold gas flow is just about at it's fastest and any disruption here (in the manifold) will affect the velocity of the gas flow as it enters into the diffuser section of the pipe which is critical.
#27
Lol, I thought that we already answered that? My feel on what they do is addressed in my earlier post #13. If you want to be exact "technically" disregard the laymans terms used and just look at my observations on what each shape seems to equate to on the track.
#28
I often browse this forum but rarely post, on this occasion I felt the need to correct a few earlier statements.
#29
I get you and did not mean anything bad by what I was saying, so my apologies if it came across that way! All that I was getting at is that a lot of people wont even have a clue what gas flow, back pressure and sonic waves even has to do with how a pipe works lol, that was it. In any case you obviously have a good understanding of things why not join in more often when visiting, I'm sure we will all appreciate/benefit from it!
