What's a good way to clean a nitro motor?
I have a Orion CRF Wasp that I thought needed a new piston and sleeve. But then I found out what a new set cost. 170. Ouch. Took the piston and sleeve out and cleaned it with nitro spray. Sealed all the needles and slapped it back together. Now it seems like it got compression back. Is this a fluke?
ya it is lol cleaning a engine will not gain compression...it could have ALOT of oil lube in the engine from assembeling it which will make the engine feel like it has more compression then it does. p.m me about getting your p/s resized I have a local guy that is amazing AD Motor Workz.....I will hook ya up on your first one as he sponsors me you can send me your whole engine I can give it to him and then I can even do a break in on it so its right for ya...
Ryan
Ryan
Simple green and a few of those Pipe cleaners you can get everywhere for like $1 for 50. They fit right between the fins and you go back and forth like dental floss. You can hose off your cooling head once you remove it, just be sure its dried completely before you bolt it back on.
Inside I use nitro fuel or elec motor cleaner but I only clean it if absolutely necessary. There is no reason to tear apart a mill that's working properly. If you run a good quality fuel with a mix of syntheticnand caster then you should be good. Outside I use a brush and kalguard degreaser. Then wipe down with a towel and do another coat of degreaser and blow it off with the compressor.
simple green with denature alcohol mix plug all opening hit then use a toothbrush then compressor. work like a charm
R/C Tech Elite Member
I usually don't clean the inside of my engines except if I need to repair it or replace parts inside.
What is your address and what this guy charge to get my 1/16 scale sportwerks chaos runing ??????..It did run for a a week or two then it quit ..It is not new !!
