After pit stop flame-outs?
#16
I see a lot of people start their cars up on the box and start turning the needles before the engine has even warmed up. I like to tune my engines after they have ran for atleast 5 minutes and have 1/2 tank of fuel. Right when your pit man picks up the car, give it a blip to clean it out. If the engine is tuned right, it shouldn't flame out.
#17
I had the same problem once. I leaned the bottom about an hour or so and it never did it again.
#18
#19
Something is not right here
If you adjust the needles in warm weather, the setting will be too LEAN when its gets colder during the afternoon.
Colder airtemp = more oxygen in the air = need more fuel to have the right mixture.
#20
You know
the problem is later in the evening when the main goes down the humidity comes out and replaces the air with water thus causing a richer condition, even in cooler temps.
So it's like this
Hotter day, lean it a bit, as it cools off it makes more power, but rarely needs to be fattened up, and the later hour, humidity causes a fat running engine, not enough to make it slow, but just enough to make the dang thing flame out.
#21
Yes that is true, but you missed the issue....
So it's like this
So it's like this
Thanks Merdith
