One way bearing question.
Total nitro noob, please go easy.
I have an RTR RC8 with the .28 engine. If the one way bearing goes out, I will not be able to start via roto-start or bump box, this correct?
Also, I looked for a pull start, but can't find one. Not sure if I'm just not searching correctly or what. Any info on this would be greatly appreciated.
Thanks, folks.
Thanks, folks.
Thanks, folks.
Thanks, folks.
Any insight on that before I get to the hobby shop later this week? I don't know what I'm looking for at all, but I'm looking. hahaha. Just don't want to buy a bunch of wrong stuff.
Anyone have any more info?
you dont need to buy anything extra just the bump box. try cleaning the bearing and make sure the back plate is tight first.
If you plan to continue using the roto-start system I would suggest picking up a spare one-way bearing.
There are two things that can happen to a one-way bearing. It can slip, which would cause the engine to not spin when trying to start it. Slipping is most often caused by gunk in the bearing itself. Often simply cleaning the bearing will get it working again.
Or it can lock-up (very uncommon), and cause the drive gear at the rear of the engine to rotate even after removing the starter "wand". In the event that the bearing locks up, continuing to run the engine will cause excessive wear at the backplate bushing.
A starter box could be used even if the roto system is still installed on the engine..
motomatt, if the roto system bearing is faulty, will that prevent starting the engine from the bump box?
Sorry for the noobie silliness, I've been swamped at work and haven't been able to do the research.
No, BUT, the rotostart stuff will be spinning when the motor is running, Wearing the parts excessively.
You can use a bumpbox on any car that has a flywheel cutout in the chassis, other starting methods withstanding..
