New Werks Clutch
#46
Hey Ron or anyone that can help me on this. I have the losi 8ight 2.0 and i got the Werks B6/B5 and also the Werks 34mm Light pro Clutch. What i would like to know is, i install the pro Clutch to the B6 engine in this order
1. losi collet
2. Werks pro clutch set up
3. werks clutch nut
4. ballbearing
5. losi 13t clutch bell
6. ballbearing
7. Losi washer & screw to lock clutch bell
Does the gap between the flywheel & clutch bell suppose to look like that?
1. losi collet
3. werks clutch nut
4. ballbearing
6. ballbearing
#47
1. losi collet
3. werks clutch nut
4. ballbearing
6. ballbearing
Attachment 628701
1. losi collet
3. werks clutch nut
4. ballbearing
6. ballbearing
Attachment 628701
im not ron but that doesnt, look right how many shims to you have behind the inside bearing of the clutchbell ?
#49
#52
Guss, pull the bearing out and see if the bell sits flush against the face of the flyhweel (as in completely covering the shoes). If so then there are two things that you can do, 1 if you have any shims sitting on top or the flywheel nut between that and the inner bearing then remove them. If not then just judging by your picture (but it is a little hard to see) it looks like there is quite a bit of space between the flywheel and the engine which means that you can move the flyhweel back. Just use a thinner collet if you have one laying around or just remove a mm or so off of it (on the wide end (bottom)) and try it.
Regards,
Ron
Regards,
Ron
#53
How will moving the flywheel back make the clutch bell closer to the flywheel? I think he wants the clutch bell to be all the way back. The bell may not work with that clutch. If your shoes are covered all the way by the bell and it lines up with the spur gear, you should be good.
#54
Yes i want the clutch bell to cover the shoes. I try the Losi clutch bell without the ballbearing in it and sat it flush to the flywheel and it still has the gap. I think the losi flywheels doesnt work for this clutch set up.
#55
How much of the shoes are showing? Are you sure it isn't the flywheel you see?
#56
1. losi collet
3. werks clutch nut
4. ballbearing
6. ballbearing
Attachment 628701
1. losi collet
3. werks clutch nut
4. ballbearing
6. ballbearing
Attachment 628701
#59
Guss, hellsavage is correct. I just took another look at the picture and actually what you are seeing is not the shoes but rather the little raised portion of the flywheel that sits under the shoes. So everything is actually ok. Please do as he advises and just install our collet, shim for the correct amount of end play on the bearing and you should be good to go!
Regards,
Ron
Regards,
Ron
#60
Regards,
Ron
