Pre heating engine...
i use a heat gun but thats me
I've used a heat gun myself. I'm planning on picking up a Competition Heat engine warmer though. Seems like a much easier/nicer/better way to heat an engine up. Seems to me that a heat gun doesn't really saturate the engine with heat very well. The warmer should have no problems saturating the whole block with heat.
heat gun on low, untill it maxes out on temps (around 150F on mine) then switch it to high untill 200f.
The heat gun is to much of a pain to use. I use the heat band. So easy. The funny part is everyone thought it was crazy before this new heater came out. Then it becomes cool. I would highly recommend you use something to pre-heat your engines through the whole life of the engine.
I can remember 12-15 years ago you could walk through the pit area of any major motorsports race and there were no engine heaters, some teams used space heaters (equivalant of using a heat gun) Go to a race today and you will not see a team without a engine heater. The benefits are to great not to use one.
I'm a newbie so pardon my question; but why is it important for you guys to pre-heat the motor, as opposed to just running it easy until it's warm? Does it have to do with the format of the race, such as no place to warm it up pre-race by running it?
