AXE ROSSI Engine thread.....
#16
Hey Tim i have not run the X2 yet but i did run the Cobra and the X1 Mamba and yes same as you i ran the Medium to Med-Hot Plug. Hey Tim what Pipe did you run? I have a Lot of pipes to try with the X2 and i am getting the pipe Axe Rossi recommended i think it is the AXE Rossi 02121. On the Mamba we found the JP2 pipe worked the best and on the Cobra i ran an 053 pipe. How did you like the X2 will you keep running it this year are will you be Moving on to other motors?
I can seem to get about 10+ mins with the JP4, and has a smoother mid range, so that is the only reason I start there. If the track allows it, I'll stick with that set up.
I like the motor, it has the power when I need it, and the smoothness to maintain consistent runs. ...and tuned right, really good fuel mileage.
#17
I have a X1SG Mamba and its been givig me headaches since day1. Cant even hold a tune and after abt 3gallons thru it, it seems to lose its pinch. Still the same after trying it with the ODO 97 glow plug. The manual says that the default setting of the LSN is 2.5 turns out from closed. But I find that its seems to be on the lean side. Using Byron 25% and Axe 2050 pipe that comes with it. Engine has been in the store as I have totally give up on it!
#18
Did you ever try the pipe that comes with the X2 i have one coming with my motor and was gone to start with it and go from there.
It sounds like this motor is gone to fit my Driving style real good i am a Smooth Driver and like a motor with Smooth power i have run lots of motors that wear like a LIGHT SWITCH with the power and i could just never drive good with them.
When i switched over to the Axe Rossi motors i could see the motors fit my driving style.
Chris, I always start with the JP4, but will swap if I need more torque or high end, just like any other motor. I keep all sizes for tuning.
#19
What up Crews? I ran for Axe a couple of years ago. I still have running an old Mamba, two Cobra X1, and a 25 Cobra X1. The 25 is a BEEEAST, with much better mileage than a 28.
As for pipes, my team engines came with the #3010 (3-chamber) pipe, which never made it to the mainstream market, in lieu of the 2050. However, I preferred the JP3 on the 21's for shorter tracks. The JP4 is still on my Cobra 25, which replaced my RB C6 w/2045, so you know it had to be for real.
As for plugs, I caught hell with everything, until I changed fuels. After trying all the Axe plugs, and the OS-P3, I settled with the Odonnell 97T eventually.
You may want to help bring back to life the Axe Rossi thread on SGrid. When you come down the NC, please bring an extra conrod for me.
Good luck this year,
RJ
RJ
#20
Hey RoyJ i am not the same Chris Crews you are thinking of same name not the same guy i live in Arkansas. But THANKS for the info on the motors i have run Axe Rossi for like 2 year now but just got picked up by them this year. I have all ways ran the Odonnell 97T plug but was gone to give the Axe Rossi plugs a Try and see how i liked them.
Have you tryed the ColdFusion Fuel it runs GREAT with the Axe Rossi motors and the Plugs. We Broker in my friends X1 Mamba with the Axe Rossi Plug RT5 and it worked GREAT.
If you need that Rod just let me know and i can get one for you at a GREAT price and send it to you i am more then happy to help any of my RC Friends .
#23
No doubt. Most of us do.
#25
Hey crews got our motors in today. They look awsome! Fast shiping to
#29
I was interested in this engine awhile back but couldn't find any opinions on it ( or much for axe rossi at all for that matter ) so I went with a safer choice but I still wonder about it. nice to see someone giving this engine and company a bit of exposure for the rc community .
#30
THANKS Dandrat I have ran Axe Rossi Motors for the last 2 years and Love them i just this year got Sponsored by them.
Axe Rossi is just as good as any motor out there i have run with O.S. motors and Novarossi Motors and all the big name companies and my Axe Rossi would run are Out run most of them and get just as good on fuel and i have an Axe Cobra with 10gal on it good motors.
I am all so a Dealer for Axe Rossi so if you would like to try an X2 just let me know and i Can get you a GREAT deal on one THANKS.
