Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Old 08-04-2009, 10:25 AM   #1
Trader Rating: 38 (100%+)
Default Sleeve Removal Tool?
Does anyone know if there is a company that makes a sleeve removal tool?
One that will work on those tough to get out sleeves?
I've seen the JP Tools one. Does anyone have any experience with that one? Does it work well?
Are there any others?
TIA
JQ Products "Le Car" - 3 of them. Primary, back-up, and spares car
Bunch of "classic" Schumachers
Tamiya - Leopard 2A6, Tiger 1
HPI - Blitz
bushyar15 is offline   Reply With Quote
Old 08-04-2009, 10:29 AM   #2
kamlooper's Avatar
Not sure on that but what I do is put a piece of plastic (piece of servo arm) between the piston and the exhaust port then turn the crank over. Pops the sleeve right out with no damage to any parts.
barking from the sidelines
kamlooper is offline   Reply With Quote
Old 08-04-2009, 10:31 AM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
The GRP engine tooling kit includes one. JP racing also makes one.
Truthfully I would just do what Kamlooper said if you don't own a tool. I use a large zip tie though. Just slide it in the exhaust port and turn the engine over and the sleeve should pop right out.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 08-04-2009, 10:45 AM   #4
RJNicholson's Avatar
If it doesn't pop out.. Warm that bad boy up with the heat gun a little. I had to do this to my Picco all the time as its fit was really tight.
Just make sure the engine isn't to hot to hold or just get a pair of the gloves out..
*Team Terribles*
Rigs Listed Below
Losi 8IGHT 2.0 B/BCE Chassis/OS VZB *Sleeper*/RE11/JRHV Servos/KHZ
Losi 8IGHT 2.0 B/Werks B7 Pro/2013/Hitech HV Servos
Losi 8IGHT 2.0 E/Mamba Monster ESC/Xcelorin 2100kv or NEU Castle 2650kv *RIP-LIPO FIRE
RJNicholson is offline   Reply With Quote
Old 08-04-2009, 10:51 AM   #5
Thanks for the tips. I've used zip-ties and even a soft piece of wood.
I wasn't sure about heating up the case, I figured the sleeve would expand the same as the case so it wouldn't really make a difference....
I've tried the grp one. Doesn't work for crap. Its about as powerful as sticking your finger in there and trying to pull it out that way....
Maybe if you can't pull it out with a tool like that it means any other method would damage the sleeve if it takes more force than that....
HPI - Blitz
Old 08-04-2009, 11:44 AM   #6
captain america's Avatar
I would never recommend trying to pull the sleeve from the top, since you can scratch/gouge it that way, or in some instances where you have a lot of ports, you can even cause the sleeve to break, since there's very little brass between some of the ports.
You can make your own tool like I did: it's basically a 7mm acrylic rod that I shaped to have a slight "S" bend in it. Remove your backplate, position your piston at the top of the stroke so that the sleeve edge is uncumbered, place the rod against the bottom lip of the sleeve and just give a little push. If it's really in tight, you can use a hammer to gently tap the acrylic rod, and it'll come right out. No fuss, no damaged edges, no splinters; works like a charm every time
captain america is offline   Reply With Quote
Old 08-04-2009, 12:29 PM   #7
the jp tool works well, i have it and have never had a problem with it. you do have to get the oil out of the sleeve so the rubber will grip and pull the sleeve.
Thanks Todd
www.bluegrasshobbies.com
Todd Green is offline   Reply With Quote
Old 08-04-2009, 12:37 PM   #8
A jp one wont remove a stubburn sleve i have tried it and it didnt go well
ericsp2 is offline   Reply With Quote
Old 08-04-2009, 12:49 PM   #9
RiverDiver's Avatar
+ 1 on lange zip tie.....or a freezer pop stick through exhaust port it will only move up about a quarter inch or so if that much. Good luck!!
_____________________________________________________________________________
RADICAL RACING ENGINES www.gotnitroonline.com
ScoTT RaCe TeaM
-.- D8 621T
-.- ST-RR 621T
TuRn and BuRn!
RiverDiver is offline   Reply With Quote
Old 08-04-2009, 02:23 PM   #10
Akhor's Avatar
I also use the zip tie method.. Never had an issue.
--Blaine--
Losi 8ight-E 2.0, Mugen MBX 7, Mugen MBX 7 Eco
VBC D07, VBC D08
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 08-04-2009, 02:49 PM   #11
reggie l.'s Avatar
i use needle nose pliers with the rubber handle and push it out..
_ClockWork-Racing_
http://www.clockworkracingengines.com/
~8t 2.0
~MUGGIFIED Lst-xxl
reggie l. is offline   Reply With Quote
Old 08-04-2009, 02:54 PM   #12
+1 on the zip tie. Save your money for tires or fuel.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 08-04-2009, 03:08 PM   #13
Integra's Avatar
i would be weery of doing it this way....ive torn the end of my rubber covered plyers before and it would suck to push so hard it tore the rubber and next thing you know you go a Big scratch up the sleeve......I would suggest the zip tie truck as it involves not removing the back plate.
Old 08-20-2011, 06:25 AM   #14
Default Which sleeve removal tool?
Sorry for digging up an old thread. I'm looking at picking up either the:
JP Racing -Tool for sleeve dismantling (21) # 93866
http://www.jpracing.com/en/products/...ries/index.php
OR
Fioroni - Motor Sleeve remover .21/.28 # OT-UT50
http://www.fioroni.com/inglese/prodo...gua=ita&cerca=
Which would you recommend or are there any better alternative tools out there?
Thanks in advance.
John. is offline   Reply With Quote
Old 08-20-2011, 07:11 AM   #15
Integra's Avatar
Attachment 797387
OR
Attachment 797388
Thanks in advance.
The Fioroni doesn't work very well, If the sleeve is Loose enough to pull out with your Finger's the Fioroni will work, If not your still stuck to with the old methods.
Rayaracing sleeve resizing and tooling jbrow1 Offroad Nitro Engine Forum 1307 01-10-2017 04:12 PM
Official Go Engines Thread MassiveMods Australian Racing 1862 02-13-2012 05:44 AM
STS .28 pull-start engine dino.tw Onroad Nitro Engine Zone 632 08-31-2009 07:10 AM
Y-Rock Innovations/Sleeve Resizing Geo Y-Rock Nitro Off-Road 13 03-31-2009 02:28 PM
jp 12 engine horror sonik Nitro On-Road 143 07-06-2005 12:46 PM
SEO by vBSEO 3.5.0
