Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 12-09-2016, 11:52 AM
  #8791
houston's Avatar
Trader Rating: 96 (100%+)
Originally Posted by cczjordan
No problem
Hope that helped ya
houston is offline
Old 12-20-2016, 04:33 AM
  #8792
cczjordan's Avatar
Default Keep off 4/4bttwc head shim
I'm running both engines with 41033/41032/41031/41021+2096, is it possible to run 0.6mm or 0.7mm head shim to gain more bottom, always on c5gtn plug, please advise. Thanks in advance
cczjordan is offline
Old 12-22-2016, 01:43 PM
  #8793
houston's Avatar
you can run .60mm shimming on head button if you want .... i wouldnt recommend it with 30% fuel or on a newer high compression engine but on 25% or less and well broke in ... should be good
i usually run the .80mm until engine "drops its nuts" then go down to .70mm running 30% nitro on all my FUSION X engines which are pretty standard old 16.26 x 16.80 bore x stroke combo .. they run awesome
houston is offline
Old 12-23-2016, 12:32 AM
  #8794
Palebushman's Avatar
Does your Fusion X .70mm "DIN's" shim stack, still give you the recommended Squish Band gap of .60mm to .65mm for 30% fuel Houston or is that not a problem with those engines at sea level?
Palebushman is offline
Old 12-23-2016, 06:31 AM
  #8795
cczjordan's Avatar
Thank you
Old 12-23-2016, 11:19 AM
  #8796
Merry Christmas and a Happy New Year Monty! Hope your health and family area awesome.
Chris Reilly is offline
Old 12-23-2016, 02:06 PM
  #8797
houston's Avatar
i request my engines to be shimmed at .80mm from novarossi .. two x .30mm and two x .10mm .. this way you can remove a .10mm after a while ... still use 30% fuel
.70mm is perfect for 30% on the fusion x engines with head button 28028 after the "DIN's" ...
.60mm shimming is pretty tight quarters for 30% ... at .50mm the piston will hit the squish band area of the combustion chamber if there is any slop in the rod
hope this helps
Merry Christmas to all.... and a prosperous new year
houston is offline
Old 12-23-2016, 04:13 PM
  #8798
hope this helps
Thanks for the tip there Houston, much appreciated.
Hope you and your family have an enjoyable Christmas and the 2017 will keep you all safe and well.
Old 01-01-2017, 09:38 AM
  #8799
ehames005's Avatar
Trader Rating: 74 (100%+)
BBBRRRRRAAAAPPPPP 2017!!!!!!!
houston likes this.
ehames005 is offline
Old 01-16-2017, 07:44 PM
  #8800
revo61's Avatar
Trader Rating: 18 (95%+)
Has anyone used Avid ceramic engine bearings before? Are they any good?
revo61 is offline
Old 01-21-2017, 02:14 PM
  #8801
houston's Avatar
ive installed a ton of them as replacements in my fusion x engines for guys ... not 1 failure that i have seen in 14x25.8x6mm
trying out JT bearing in my personal engine for buggy ... only been able to put one race on it so far but so far so good
i need to race more
houston is offline
Old 03-04-2017, 03:47 PM
  #8802
houston's Avatar
yes sir ... good times were had
good job on your sportsman Amain !!!
ehames005 likes this.
houston is offline
Old 03-07-2017, 05:34 PM
  #8803
ehames005's Avatar
Thanks Monty!!! The X5 Race, ran flawless all weekend!!!!!
Old 03-16-2017, 11:34 AM
  #8804
Hi Monty
Got great deal on a Brand New Bonito.
Looking to put in a MP9 /Truggy
What is the best pipe/header and clutch of this motor?
And any other tips for shimming etc.
Many Thanks
Tom
Tomigun is offline
Old 03-19-2017, 09:10 PM
  #8805
jeromerc's Avatar
Great run Monty in Buggy..... Million dollar question though is did you show Kanai San on the podium your Mugen buggy
jeromerc is offline
