Rw modding and engine rebuilding
#61
My latest projects/ experiments have been titanium wrist pins for the Go engines. They would work on other motors but on the Go they tend to wear the pin and the piston due to the fit not being tight enough from the factory. (they may be tighter on the new Gx series) So I made a titanium pin slightly larger to make the fit tight again, this almost needs to be custom to each engine like during a rebuild.
I also have been putting a dome shape in the backplate for a little more case volume on some engines.
I also have 5.5 and 6.0 restrictors ready to ship, I'll try to get some pics up this week. They are $13.00 each.
Rex
Rex
#62
Hey Rex,
Have you fully-modded a GX series yet? Do you have any and how much would you want for a 5 or 7 port fully-modded? Also, how much would you charge to fully-mod one if I got it from someone else?
#63
I charge $50.00 to fully mod. $10.00 less on a Go bought from me. I have 5 Gx 5 ports on order with 2 spoken for.
Around $255.00 for a Gx 5 port fully modded new, $280.00 with the 2072 pipe. 7 port would be around $15.00 more I believe. I am going off the map price I last saw, hopefully it wont change.
Rex
#66
I thought I would post a few pics explaining part of my process of rebuilding an engine.
First I disassemble everything, put the block, backplate, head, and take the front bearing out and pop the seals off. next I wash everything in a high pressure hot alkalai cleaner. I have seen pictures and video's from other shops that rebuild motors and have not seen any kind of cleaner in the shops. It is very important to have everything clean! In the other pic I am showing the bore guage I check the rod with, each number is one thousandth, so it reads down to .0001.
Rex
Rex
#67
I picked up a few Skf front bearings at a good price, they are very good quality. I am offering a $40.00 rebuild and this will include replacing the front bearing with a new one. Rebuild includes Cleaning, inspecting everything, resize sleeve, professional assembly. Any other parts are extra.
E-mail [email protected] or pm me.
Rex
Rex
#69
i have 2 p/s to get pinch. what are your prices. thanks
#70
$15.00 for one $25.00 for 2, return shipping in the Us included.
$37.00 if you send the whole motor, inlcudes sleeve resizing, cleaning, inspection, replacing any parts. (parts extra) professional assembly. If I get a motor that is not worth fixing you only pay return shipping.
Rex
Rex
#71
rex is a good guy he'll take care of ya.
#72
Hey, that's my engine Rex does a great job with engines. I use him all the time.
#73
Rex,
Do you have alpha engines in stock? if so what are the prices on the Z852? thanks
#75
ohhh preeeetty... wonder who's engine that is?
What epoxy are you using for the ramp?
