Go Back   R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Thread Tools Search this Thread Rate Thread
Old 03-18-2009, 06:29 AM   #76
RiverDiver's Avatar
I run a few of them.....they run great never get real hot and always have more than enough power to clear the big jumps!!
_____________________________________________________________________________
RADICAL RACING ENGINES www.gotnitroonline.com
ScoTT RaCe TeaM
-.- D8 621T
-.- ST-RR 621T
TuRn and BuRn!
RiverDiver is offline   Reply With Quote
Old 04-12-2009, 05:09 PM   #77
RiverDiver's Avatar
Thanks to Dave Simpson @ GOTNITROONLINE.COM I picked up another podium finish. Engine ran very smooth with EFRA2010 (one spacer) on my Kyosho ST-RR w/Nitrotane. Usually I run Byrons Gen2 but I did have very good results with the nitrotane.....could have easily gone 11mins.(621t)
If anyone has questions about these engines........ 6 port perfect for buggy or truggy/ Fully modified from factory/ and run like a striped azz ape. Large cooling head heep them sub 220 / run good with 20 percent nitro content to 30/ Usable power all through the RPM range/ also come with the venturi carburator with 3 diffrent inserts. Engines can be purchased via GOTNITROONLINE.COM
I come from running an O.S. SPEED, so the switch was well worth it!!!!
ScoTT RaCe TeaM
-.- D8 621T
-.- ST-RR 621T
TuRn and BuRn!
Old 05-08-2009, 12:03 PM   #78
skrizz1777's Avatar
Trader Rating: 11 (92%+)
Do you guys suggest removing a shim to run 20%
skrizz1777 is offline   Reply With Quote
Old 06-24-2009, 08:21 AM   #79
well i had a bit of weeping at the front bearing after racing last week so thougt i would change the front bearing,she has done exactly 6 gallon now so not too bad
pics are as it came apart,nothing cleaned up,been run on 25% odonnels,p3 plug and hn2047 pipe.
rear bearing is fine and the conrod/crankpin has zero play..and i do mean no play,amazing build quality and materials used.
might just have to order another one for next year
Thankyou to my sponsors: GO Engines : Answer-RC : Optifuel
fastboy is offline   Reply With Quote
Old 06-24-2009, 09:15 AM   #80
v6shooter's Avatar
Amazing engine,I have one with more than 6 gallons no play in rod and crank pin and piston and cyl have lots of more life to go. Under rated engine never flames out great power and get 9 1/2 mins per tank cant ask for a better engine
v6shooter is offline   Reply With Quote
Old 08-06-2009, 10:23 PM   #81
RiverDiver's Avatar
Doing well in the larcc series with these engines......check it out.............Dennis Van Dyke Expert Buggy/Truggy......hoping soon to have more points on the board very soon!
http://www.larcchallenge.com/LARCC.P...oints.2009.htm
ScoTT RaCe TeaM
-.- D8 621T
-.- ST-RR 621T
TuRn and BuRn!
Old 10-07-2009, 01:28 AM   #82
well just coming upto 10 gallons on mine now,only thing i have changed is the front bearing!
theres a tiny bit of play on the conrod and rear bearing so i might just chuck a new bearing in there and let her run her natural life out,still pulls like a train and smooth as butter,idles nice and low and consistent,i have only had 1 flameout in the whole time i have had it and that was when the idle dropped when the pinch went.
compression is still pretty good,ok its not got any mechanical pinch but 10 gallons what more can you ask lol..oh and thats uk gallons which is about 12 U.S. gallons.
its a real shame it makes then too expensive to buy (for me as i live in the UK) and import duty cripples the price but for you guys in the usa..dam your lucky!
dave
Old 02-16-2010, 06:34 PM   #83
Trader Rating: 16 (100%+)
just wanted to get this thread back to the top. This is an awesome engine, anybody running them
Chris Marrant
Marrant's R/C Speed Shop
Let us help make you a winner!
Kansas City, Mo
gofast072 is offline   Reply With Quote
Old 02-16-2010, 06:54 PM   #84
I run a 621t in buggy and truggy and let and let me tell you this engine has more all around power than anything ive ever driven there wont be any jump someone at the track is making and you just dont have the power to do it, that wont happen with this engine believe me its got plenty. And on top of its power its got good runtime around 10min in both buggy and truggy. If you havent checked this engine out you are definately missing out on something great engines lasting 12 gallons for $280 with tons of power and good runtime definately a winner.
Chris Marrant
Kansas City, Mo
Old 03-04-2010, 06:43 PM   #85
I have a 621P with no venturi/restrictor. Anyone know where i can get one or if any other brands will fit?
stevef is offline   Reply With Quote
Old 03-04-2010, 06:45 PM   #86
Mindcrime's Avatar
Send a message via AIM to Mindcrime Send a message via MSN to Mindcrime
Not all of the Radical carbs use restrictors.. are you sure your does?
Westgate Imports
Radical R/C Engines
Byrons Fuel
Panther Tires
Mindcrime is offline   Reply With Quote
Old 03-05-2010, 06:36 AM   #87
pretty sure it does, the throat of the carb is very large before it necks down. Ill post a picture a little later.
Old 03-05-2010, 09:27 AM   #88
photo attached.
Old 03-05-2010, 02:55 PM   #89
Stanton's Avatar
Originally Posted by stevef View Post
photo attached.
Steve,
That carb is missing the restrictor. Dave can get you new ones at GNO. If he doesn't have any, I can give him some of mine for him to send you. Also, if your in a pinch, you can use a Dynamite or NR carb on that engine.
Mike Stanton
Horizon Hobby/Spektrum/Blue Thunder/TLR/Dynamite/Radical Engines
Stanton is offline   Reply With Quote
Old 03-05-2010, 04:18 PM   #90
thanks mike. Ill give them a call.
Sponsored Links
RADICAL and OPS Engines rccarracer15 Offroad Nitro Engine Forum 65 01-22-2013 06:21 PM
radical 621 p patrick lsp R/C Items: For Sale/Trade 1 06-23-2008 03:02 AM
radical 621 p patrick lsp Nitro Off-Road 7 05-18-2008 09:41 PM
<<<RADICAL 628>>>LIKE NEW f/s---f/t thebert686 R/C Items: For Sale/Trade 12 01-08-2008 10:26 AM
anyone have a 621 radical? blasterman456 R/C Items: Wanted to Buy 0 12-14-2007 08:42 PM
SEO by vBSEO 3.5.0
