Model Technics fuel.
anyone ever used it? i bought a gallon last night and the fumes dont smell like nitro it seems to be quite good though. i got the special off road blend 16%. its orange.
I also use this fuel, runs fine with the Jato
Never heard of it.
Model Technics Fuel
Its a fuel from England
I use the big bang fuel 20% with there sical technology. It gives me the same performance as 25% but it's cheaper (£16 for a UK gallon) and my engines (RB WS7x3 and OS VZB) are into there 6th/7th gallons and still have their pinch. I never have to put after run oil in either as they have a really good oily coating inside the engine that stops the rust.
Here is a link to explain
http://www.modeltechnics.com/display.htm
Click on each line to read more
Well worth a look if the price is good in the USA
i have to say, even just a quarter of a tank getting the idle set right at factory settings i had a lot more punch than with the cheap home blend i got with the car. it also sounded more consistent than the other fuel, and i could idle for huge amounts of time right on the borderline between going and stalling. as i accellerated it sounded really different. more.. defined i guess you could say. i woujld recommend trying this fuel!
hi, do you recommend to use this fuel instead of other brands? i am still not so sure about it
