Go Back  R/C Tech Forums > North American Regional Forums > Northwest Racers
Premier RC Raceways & Hobby thread >
Old 06-03-2014, 03:17 PM
  #46
the big rc's Avatar
Trader Rating: 40 (100%+)
First look at the place and it's huge!! http://www.thebigrc.com/?p=5729
All I can say is this is gonna be amazing. This is the first day in there, and even though it's being cleaned up, I was just in awe! Can't wait to run on it!
the big rc is offline
Old 06-03-2014, 03:20 PM
  #47
DJM75's Avatar
That's awesome! I need to hurry up and get the rest of my gear so I can run when it opens.
DJM75 is offline
Old 06-03-2014, 06:06 PM
  #48
Troy Mckune's Avatar
Trader Rating: 51 (100%+)
Stopped by today and OH YEAH!
I am currently down at RC Plus. Good news, panther slicks rock on carpet. I wish i had my front slicks as well. I heard Cameron brought this up a while back. They are very hooked up but also a little forgiving on aggressiv driving.
Sent from droid.
Troy Mckune is offline
Old 06-03-2014, 06:55 PM
  #49
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Sent from droid.
I was very successful running them on carpet. A little sticky kicks on them to help with the bite for a the first few laps but when they get warm they are very fast. Much like on road rubber tires. 4w a few burnouts on warm up laps to get them warm and your good to go.
Cameron Kellogg is offline
Old 06-03-2014, 07:37 PM
  #50
So slicks are just fine on 4wd sct? Maybe I won't need mini pins after all.
Also what should I do to my 4wd sct as a basic qui decline setting it up for carpet?
traxxas13 is offline
Old 06-03-2014, 07:59 PM
  #51
SC there is a trick I do to the front tires to reduce corner bite. Actually a euro trick they use. JP reminded me of it when I was fighting going on two wheels in every corner.
About 1/4 inch of super glue on the outside edge of the front tires is all it takes. Kind of easier to show you than describe it.
Old 06-03-2014, 08:21 PM
  #52
Suspended
Pics!!!!
CCraig1984 is offline
Old 06-03-2014, 08:55 PM
  #53
motomanpat's Avatar
Originally Posted by TopGear_RC
Offroad/ onroad 80x48 oval is 75x40 ish
Thank you for the reply!
motomanpat is offline
Old 06-03-2014, 09:56 PM
  #54
Defiantly pics will help. Just need to get some slicks first since my wheels are bent to all heck.
Old 06-04-2014, 07:15 AM
  #55
Trader Rating: 20 (100%+)
Use a q-tip to run a 1/4 strip of glue around the outboard edge of the tire's contact patch. Don't glue the q-tip to the tire, it'll throw off the balance. I've used this trick on high-bite clay, as well. It always felt like a band-aid, but it works remarkably well.
Sorcerer001 is offline
Old 06-04-2014, 10:10 AM
  #56
tomdav's Avatar
Trader Rating: 44 (100%+)
+ YouTube Video
Jumps look legit in this vid. I have a few hours today if you need some help
http://youtu.be/9yvwqTi54k4
tomdav is offline
  #57
Definitely sounds defiantly good for sure!!!!
woolleybully is offline
Old 06-04-2014, 10:15 AM
  #58
Don't glue the q-tip to the tire, it'll throw off the balance.----LMFAO, kinda like walkin out of the bathroom with TP stuck on the sole of your shoe. LOL
Thank You for the pic Kevin!!! Wow is right!!!
Gene
Old 06-04-2014, 10:34 AM
  #59
So just normal super glue or the gel type? Cause normal super glue seems to run all over the dam place.
Old 06-04-2014, 10:53 AM
  #60
In on road we do this all the time to foam tires and sometimes rubber. We did this to our F1 cars a lot. Normally just use normal super glue. Put your car on a stand so that you can freely rotate the tire. Spin the tire slowly as you apply super glue from the bottle. Start near the rim and work up putting a light coating of glue on. You can then use the side of a hex wrench shaft or screw driver shaft to even out the layer of glue even more. You want a thin coat so it does not run and dries on it own rather quickly. Do not use zip kicker because it will bubble. Apply more coats as needed.
