Broken Slash 4x4
Broken Slash 4x4
I was just running my slash 4x4 with my new max amps battery
it was running fine untill i think i stripped a gear or something???
When i pull the trigger the motor spins but truck does not move nor does the shaft. ???
Does anybody fix these bad boys ?? I dont want to get it apart and not be able to get it back together?
Tammies hobbies in Beaverton can get you going.
I run mine with 2s LiPos and I run stock gearing. One problem that you might experience is the bearing on the slipper unit seizing and tearing up your motor carrier. You might want to check that out as well as the gears.
all the detail info is on the manual, or you can download for Trx website,
http://www.traxxas.com/products/elec...h4X4_views.htm
