NWIC 2010/11
#16
Here's my thing: I would gladly compete in novice/sportsman only, to keep out of the way of the better drivers, but it wasn't really an option. I tried it one season, but not all the tracks offered that class. If I'm going to invest the time, money, and effort into attending every race, I'd like to see my race results all be counted at the end of the series, even if I am just in it for the fun.
TTFN,
Grem
TTFN,
Grem
#17
NWIC 2010/2011 Classes?
Stock 17.5 Rubber Tire Sedan Limited Profile ESC (NO Sponsored drivers)
Super Stock 17.5 Rubber Tire Sedan Open ESC
Modified Rubber Tire Sedan Open ESC
13.5 1/12 Scale Open ESC
Modified 1/12 Scale Open ESC
World GT 13.5 Limited Profile ESC
Expert World GT 10.5 Open or Mod World GT Open
That would eliminate Foam Sedan from last year but add 1 more 1/12th scale and one more World GT. Total 7 classes with a pretty good mix of beginner, Intermediate, and Expert classes. The mod sedan class seemed to be optional last year based on if Dave, Kody, and Darren showed up. This year it may have more of a following with Devin, Tim, and others since there is no 13.5.
Troy
#18
The WGT class would have easily been the largest class last year and would be this year if it had 13.5 and mod, or at the very least dumping the 13.5 for a 10.5, if it's going to be just one class. It seems that all the angst comes from the spec stock classes. IMHO there should only be one stock class for each chassis class with no esc boost etc. The huge jump from stock to mod doesn't mean much unless your a mid pack stock spec racer and you think you expect to podium in mod. I expect there would be more racers that would want to try a mod class, if there were just the two classes. A fuller mod class would be more fun and made up of the new slower mod guys the intermediate faster guys and the top elite guys. Right now it seems like the mod class has just the intimidated "what the hell am I doing in this class guys" and the few top elite guys, there is not enough mod racers for the new and intermediate guys to compete against and improve, so they don't get discouraged and drop back down in class, or don't want to give it a try in the first place. Building a good group of mod racers is a big part of a successful track, with their experience and knowledge they share with other racers is invaluable, plus they are pretty fun to watch race.
#19
Troy
#20
I like the purposed classes. Somebody posted a list of last years class entrants, and stock had the most, super stock had the 2nd most, and mod had the least. If you take out 13.5, they will motor up or motor down. So that will split and grow stock and mod into bigger class numbers. Heck, rename mod to "open" and people will run there 17.5s in the class. The mayhem that causes passing people outdoors is bad enough, let alone RCPlus type smaller lanes. But they will get punted (without cause) into the lower mains by cars that can't help but punch out of corners.
Another suggestion, open tire the series. I know some of you hate blues as much as I do. And with Sweep getting big in the NW, and how much I like SJR premounts, it be a positive for a lot of people.
I'll be turning 18 in November, so my parents can't hold me from winter racing anymore like last season. Haha.
#21
The classes sound ok to me too. One change i would like to see is 12th 1s 13.5 and a spec tire. The spec wgt class was more fun for me as it had a level playing field . I don't want to have a huge box of tires for 12th anymore. 12th with no speedo limits and spec tires would have a better draw for guys like me that can't handle mod so well.
ME
ME
#23
Once you get a baseline setup for the Tekin there is no need to change it. Once you get the gearing and rpm's set you really dont need to touch it. That's my opinion of course. Having the option of tuning you esc is much easier/cheaper than carrying 14 different motors to figure out what combo you want to run that weekend.
#25
TTFN,
Grem
TTFN,
Grem
I do see a need for possible a third rubber class. ONLY IF ITS NOT THERE FOR PEOPLE TO RUN TWO 17.5 CLASSES. Run 12th scale guys and you will get better driving skills from it. I know this wont work as the third class will be put into place just to get the entry numbers up.....
#26
That was Easy! LOL
Spec Tire for rubber classes TBD maybe Sweep
13.5 1/12 Scale Open ESC with Spec Tire TBD
Modified 1/12 Scale Open ESC open tires
World GT 13.5 Limited Profile ESC WGT Spec Tire
Mod World GT Open ESC WGT Spec Tire
#27
Troy
I agree with the stock class... Let this be a good place with a good pace for the newer racers getting into the NWIC. 17.5 with turbo boost is just to fast for a stock class...
#28
Stock 17.5 goes back pretty much to where it was at the beginning of last Season. Fast enough to be fun but slow enough for the sponsored/super fast guys to avoid.
Super Stock 17.5 is faster than 13.5 was a year ago.
WGT goes back to no timing adv and is the class that it was intended to be.
I personally would like to run 13.5 Super stock 1/12 and Mod GT. Maybe a little Super stock 17.5 sedan here and there.
Mike, I like the idea of a spec tire for super stock 1/12th.
Troy
Troy
#29
This is just another aspect of the NWIC that needs to be worked out...
#30
Troy
Troy
I will check the KV's and do the math and post up.
