ROUND #2 ECT A MAIN R/C RACEWAY NOV 15th!!! ROUND 1 153 entries don't miss out!
ROUND #2 ECT A-MAIN R/C RACEWAY
$22.00 PER ENTRY
DOORS OPEN AT 8 AM
Qualifying
A- Starts
1-Staggered starts. Each person will be individually clocked.
2- There will be 2 minutes between the finish of the race prior to the start of the next race.
B- Qualifying runs
a. 2 rounds of qualifying. Using single fastest run to determine your main event position.
b. 8 cars or trucks will make the main event due to track size at TRCR,Mike’s R/C World and Four Seasons R/C Raceway. 2 bump ups from lower main events will fill the 10 car main events at these tracks
c. 6 cars will make the main event due to track size at A Main and Independent R/C. 2 bump ups from lower main events will fill the 8 car main events.
d. Qualifiers will be 5 minutes in duration.
Main Events
A- Starts
a. Starts will be heads up based on qualifying position. One front tire is required to be on the line at the start of the race.
B- Main event Format
a. Triple A Mains will be used at all races this year. All lower main events will be single main events. Tie Breaker will be the 3rd race.
b. All main events will be 5 minutes unless otherwise noted
A-1 Point per event entered
1 point for TQ
100 points for a win with each lower position losing one point.
best 4/7 races count
B-Trophies to the top 5-10 at the end of the points series depending on turn out in each class.
1 free entry to the champion of each class the following year
Classes:
novice
Slash
Stock Truck
Stock Buggy
Super Stock 4wd
Super Stock Truck
Super Stock Buggy
Modified 2wd
Modified Truck
Modified 4wd
Class Rules:
Stock Buggy and Truck
A- Legal Motors
a. Any Machine Would 27 Single approved by ROAR
i. Bearings may not be added
b. Any 17.5 Brushless motor approved by ROAR
B- Batteries
a. 2 cell Li Po's will be legal. Car MUST BE legal ROAR weight
b. Sub C cells must still only be 6 cell
C- Tires
a. Buggy Front: Panther C compound Bobcat
b. Buggy Rear: Panther C compound switch 2.0
c. Truck Front: Panther C Compound micro rib or : Panther C Compound Switch 2.0
d. Rear: Panther C Compound Switch 2.0
Super Stock 4wd,Truck,2wd Buggy
A- Legal Motors
a. up to 19 turn brushed
b. Brushless 13.5 and 10.5
B-Tires
Tech-
Unless noted all cars must pass tech to ROAR standards. Ex: weight and width.
So far this year the topic of discussion has been the Slash The rules are pretty much set on what we will allow as modifications! This should be a great class to help continue the fun factor!
-kit motor and esc
-kit wheels and tires
-kit shocks and springs
-no aluminum (shock caps ok),carbon fiber or graphite up grades
-kit servo
-slash bodies (traxxass or pro line) only. custom paint jobs encouraged
-any receiver
-any battery up to 7.4 volt
-any battery connector
-any gearing
-PTs allowed
-reverse allowed
-no weight restriction
-no swaybars
Slash Racing Format
Qualifying
-heads up starts
-round 1 will be random
-round 2 will be based on the 1st round with the fastest cars in the back
-the main event will be filled with as many drivers as can fit on the drivers stand
-main event will be determined by finishing position from the earlier qualifiers. Using the best finish that each driver has will determine the main event
- Main event starting grid will use all trucks backed up at a 45 degree angle to the straight away. 1/2 on one of the stright away and the other half on the other. Starting position will be determined based on the winner of the first round heats starting on the back and so on.
- winners from the first round will continue to race in later qualifiers to promotoe blocking!
- rubbing will be encouraged
- turning around to run backwards will not be allowed
-rules can be changed and updated as season continues!
2008-2009 ECT
Round 1-Sunday October 26th Tacoma R/C Raceway
Round 2-Saturday November 15th A Main R/C Raceway
Round 3-Saturday December 6th Four Seasons R/C Raceway
Round 4-Sunday January 18th Tacoma R/C Raceway
Round 5-Saturday Febuary 7th Mike's R/C World
Round 6- TBA - Independent R/C Raceway
Round 7- Saturday March 28th Four Seasons R/C Raceway
Electric Chamionship Tour Director and Announcer
PRESENTED BY HIGH VELOCITY
LUNSFORD RACING
TEAM AE
LOSI
ORION
TRINITY
INSANITY RACING
MORE TO COME!
