ROAR goes to 4cell... What will tracks do?
#16
4 cell touring cars will totally obsolete everything the stock racer currently owns, and just start another technology war for battery manufacturers to come up with a 1.4v, 1.5v, or higher exotic sub-c cells, followed by the motor folks coming out with brand new winds and exotic brushes and magnet combinations to get the same speed as the existing 6 cell cars have. It may take them a year or two to get there, but the technology will evolve and all the non-sponsored racers will have to pay the $$$$$$ prices to go fast.
I agree with all the other posters. This seems like a bad move on Roar's part. Does anyone know the history behind this alleged decision by ROAR? Who is really pushing to get these new rules made?
Maybe 4 cell touring on a smaller carpet track but I think the cars would be considerably slower at a place like SIR. But then you are saving a couple of ounces in weight, and 4 cell 1/12 scale cars are as fast as or faster than the touring cars.
Maybe the 4 cell rule will just bring back 1/10 touring pan cars or pan chassis GTP cars?
Just another reason to not join ROAR?
#17
Originally Posted by Wild Cherry
You Dummy ...
4 cell
Its for all the class`s in Sedan ....
Yup 4 cell 27T is now officially gona become turtle free....
4 cell
#18
point is, some will try it (like cj) and give a report back to us.
#19
Registered User
By going to 4 cells that means that the amp draw in the MOSFETS will have go up higher in order to keep the speed up BAD for the mosfets..
Thanks for posting this, Peter..you found something that I think most of us will agree on!
#20
Originally Posted by Skruger
I was just Kidding I have my indy 0-30 and it works just fine for me.
But how many NEW people want to buy a $50.00 to $100.00 Discharger.
I never understood people's logic like this. You will buy several $70 packs to get the best runtime and voltage then you go discharge it on the cheapest thing you can find. Makes no sense, it's like buying a Rolls and then parking it on the street curb every night.
#21
I don't think this will change the technology race one bit. All it will do is temporary slow down the cars until the technology allows the same speed that it used to with 6-cells. Then what, we go to 2-cells? Sounds stupid to me.
#22
WoW
Originally Posted by Anthony.L
I have the Integy and it gets the packs WAY too hot because it's 30amp linear. When I was using that on the 4200WC packs they were coming off like 180+ F which is not ideal for the cells.
I discharge most of my packs at just 5 to 10 amps on the Turbo35 and then use the Indy to ballance discharge only.
You are right about INDY 0-30 getting the 4200's HOT because it is designed to be used as a ballance discharger NOT a pack dump discharger like the Reactor.
and yep the Reactor Sucks Big time (I would never buy one)because I dont like to ruin my $70.00 packs either.
I like to slow discharge my packs untill 5.4volts and then apply the 30 amp Ballance discharge for only 1 to 3 min. that sould have all the lights out unless there is a bad cell. then I make a 4 cell pack out of that (BUT that is another story)
the Indy 0-35 is by far not the cheapest (I have some 2 bulb dischargers)
I am still using OLD 1400mah NiCad's and gp3300's from way back .In my TOY speed boat's. I quit using them because of the 4200's Voltage advantage
#24
I bet Ritchie can`t wait for next summer....
For that hot day on the parking lot !
Racing a 4 cell 27T sedan .....
I got to be the only racer around to approve of the rule change .
I say it will help Sedan a lot because it will open up the class`s for the beginner`s and novices..
This alone is why I support the decision...
Just look at the novice entry`s count for the sedan program`s and then maybe you could understand why this has to happen....
The sedan sport needs fresh customer`s in order to survive
or
watch it die....
#25
The sedan sport needs fresh customer`s in order to survive .
But you are right about the Novice / beginner classes shrinking.
Hay that is what Tamiya's GT3 /spec sedan /novice class is suposed to do .
but in this MicroSoft enriched land of money it dont seem to be working either.
4 cells will just ruin more speedo's in the sedan class
#26
no, actually i will be running a 3.5 or 4.5 brushless.. that is what you wanted isn't it. ran the 6.5 brushless all weekend at the gold cup even though the car works better with a brushed motor, winning isn't important to me anymore, not working on motors is. having fun and hangin with friends is even better.
#27
Couldn't you do the same thing by running longer races with the same equipment we allready have? Wouldn't that make the racer think about run time and motor wear in a new way without having to redesign chassis and electronics?
#28
I don't believe undergearing the motor is the answer. Either we continue the current path and electronics catch up, or we step the voltage down.
#29
LoL !
Blame the motor !!!!
I think I went as fast as you did !!
The motor was one of the reason`s I did though...
#30
Regional Moderator
In my opinion 4 cells would be a good thing for the novice/beginner classes. Due to less cost for start up. And slightly slower speed for learning to drive and set up.
One way to do some testing is allow 19t to run 6 cells and allow those running 4 cells to run modified motors and see if they can equal the lap times. or make the car perform better on the track. I believe it will be close in lap times and should make for a fun race with more people in it.
Personally I don't care one way or the other. Set up the rules. I'll meet them and we can sort it out on the track.
One idea is open up the rules for Modified class. Throw out the motor rules, let the Manufactures create some motors and electronics that can handle the voltages of current and future energy sources. Only rule is the car has to meet weight/size. Let them develop traction control,rare magnets, Explore armature size. Develop windings/arms with other materials. All these will trickle down and make racing at the top level something that is helping push the limits of technology. And the biggest goal is to put some cash on the potium develop a professional league of R/C racing. Or stay the course let the hobby of R/C racing die a slow death.
OOPS got off on the wrong rant.
4 cells who knows. Try it, don't try it. who cares as long as the cars on the grid meet the same rules. And the race is deciede by the clock.
