Sponsored by:
Go Back   R/C Tech Forums > Commercial/Retail Forums > NitroRCX.com
Thread Tools Search this Thread Rate Thread
Old 04-06-2017, 02:22 PM   #1
Default Dimension Professional 3 Axis Hand-Held GamaGrip Modular Gimbal Package
+ YouTube Video
+ YouTube Video
+ YouTube Video
The Dimension GamaGrip is a modular gimbal packaged designed for handheld or aircraft/vehicle use. The unit is designed primarily for compact cameras such as the GoPro Hero 3, 3+, 4, or other similar sized compatible camera units. The ergonomically designed GamaGrip is comfortable to hold for long periods of time and is able to hold your mobile device on the top of the grip for perfect live video viewing. The gimbal crane features three motorized control units and has a directional pad at your fingertips that allows pitch, yaw, and roll control. Cameras attach by securing simple thumbscrews without any tools, and full setup can be achieved within a quick timeframe. Other strategically placed buttons on the hand held device allow the user to access different mode options along with gimbal re-centering and the power button.
The handheld device is powered via an 11.1v 2200mah lithium battery for prolonged run times. You also have the option of removing the gimbal device and with just 12v of dc power you can mount the gimbal to any vehicle or aircraft allowing the gimbal motors to keep your camera steady. The gimbal crane will have 2 sets of rubber dampers that are included to tune out vibration depending on your mounting application. A set of stiffer dampeners are recommended for the GamaGrip while the softer dampers are recommended when you remove the crane and mount it to a aircraft or vehicle that has inherently more vibration.
Key Features
3 axis motorized control units
Supports compact cameras such as the GoPro Hero 3, 3+, and 4
GamaGrip with directional control pad
Tool-less camera attachment using thumbscrew
11.1v 2200mah Lipo Battery powered for longer life
Specification:
Working Voltage: 12-18v
Weight: 220g
Height: 92mm
Max Pitch Range: +45 degrees / -90 degrees (control speed 25 degrees/second)
Control Pitch Range: +45 degrees / -45 degrees
Roll: +45 degrees / -45 degrees
Max Yaw Range: +160 degrees / -160 degrees
Control Yaw Range: +90 degrees / -90 degrees
NitroRCX.com is offline   Reply With Quote
