Like Tree2Likes
Old 10-12-2017, 09:49 PM   #16
scary_jerry's Avatar
Originally Posted by wkloppen View Post
Tried to make an overview of the camber increase due to caster relative to the steering angle. It seems to work properly taking caster, static toe in and steering axis inclination into account.
You can edit the black filled fields filling out your own values. The steering angle is the toe in column and the most right column calculates the actual camber for the specific steering angle.
Note: camber increase due to pressing in the suspension has not been taken into account here. ..Might add that later but it's late and i wanna go to sleep
https://docs.google.com/spreadsheets...it?usp=sharing
w.
Hey W, do you think Einstein would take a nap now.....😎
If you solve this, I'm thinking NOBLE GT8 AWARD !!!!! 😎
scary_jerry is offline   Reply With Quote
Old 10-13-2017, 05:07 AM   #17
wkloppen's Avatar
Ok.....was rather late yesterday evening calculating all the angles and formulas. Luckily the formulas are correct as I did a lot of testing. I made the sheet muchmore easy to understand including a graph which shows you the actual camber at a given steering angle.
It takes the SAI, the camber at zero toe (static camber) and the steering angle into account. The SAI (steering axis inclination) is bit difficult to measure but has a slightly negative effect on the camber increase while turning the wheel although it's not much as the graph clearly shows.
Have fun with it....
30Tooth likes this.
___________________________________________________________
Serpent Cobra GT RTR with XRD 5 ports engine, Novarossi GT manifold (41032), 4 chamber Hypex low noise exhaust, GRP (S5, S4) tyres, Sanwa M11X, Savox 2290
wkloppen is online now   Reply With Quote
Old 10-14-2017, 09:30 AM   #18
Location: Beneath a rock down by the river. Don't have money for van
Kick up isn't bad by itself, nor caster. Once I feel more healthy I will write to the GT8 group about both and how you can tune them.
( ͡ ͜ʖ ͡) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old Yesterday, 10:15 PM   #19
wkloppen's Avatar
Default Measuring total caster
I did some measurements on the Serpent yesterday evening. The total caster measured 22 degrees on the setup tool. With the 12 degree steering knuckles would leave 10 degrees for the kickup of the suspension arms. I know the actual bend on the serpent chassis is approx 15 degrees which means the lower arms are not paralell to the chassis bended front but have a 5 degree lesser
kickup.
Conclusion: you have to measure the actual kickup of the lower arms instead of only the bend in the chassis which makes perfectly sense. I reckon this will be different for each chassis brand.
w.
2wd kickup...necessary? one-nil Electric Off-Road 6 11-28-2012 11:18 PM
