VRC
#31
Originally Posted by ChApS
Whats peoples fastest time around Olso Norway (comes with the Track) Only can manage to do 14.5's around it using the keyboard.
For what scale? I do 13.8 for 1/10 and 12.4 for 1/8 i don't bother with 1/10 lola anymore but that was around 13.4
#33
Should get the adaptor it is worth the money, you go alot quicker and this year they are having money prizes and they are giving away serpent 710 in a winternats race in about 2 weeks.
So you can win the money back in prizes you spent on the adaptor.
#34
2nd that !! The adaptor makes VRC a much more realistic experience
#35
13's thats fast.
Yeah i only realy use 1/10. I find 1/8 so hard to control especially comming off the sweeper.
#36
yes it is worth getting the adapter but i only use vrc offline for practice.I have no time for vrc with schoolwork lol
#37
I have a question.....when you guys running 1/8th.........(or may be 1/10th, but 1/8th gave me a lot more problem then 1/0th).....does you guys use the RADIO SETTING (just like the real RC racing) for the VRC...?
I find the 1/8th are too "tweaky" on the steering....and no matter how I setup the car, or use the listed setup from other driver's spec...it is still NOT as controllable as a real thing...
#38
I find its better to change setup rather than things on the control as your going to be going on 20 different tracks you can't keep changing things on control you forget whats what for each track.
So i make a setup for each track and leave the control settings at stock except i have dual rate at 95 and brakes at 24 as i use one way but thats it.
I never found steering to be tweaky though unless i stuffed around alot with setup.
Try to find a good neutral point on control to work for each car and track and adjust setup to suit.
#39
Maybe useless to tell, but don't forget to also upgrade your tracks, if you have upgraded to a newer release.....
#40
im havin fuel economy problems on the speedway. i run out before the 3 mins and ive only done 27 or 28 laps. how do people get up to up and that one guy to 34.
#41
bigger tank?
Maybe more memory in your PC....
Sorry.....
Sorry.....
#43
ok, do i make the gap larger or smaller? i dont know anything about centax clutches
