Bodies made by Blitz ( anyone have a review ?)
One of my local shops just got these bodies in. They are .8 lexan !!! That's almost 3 times the thickness of other brands. Anyways, I was wondering if anyone has ever tried one of these bodies.
Thanks for the input. |
try www.team-titan-ca.com the race report link. there have lots of reviews on the bodies.
Originally Posted by suntok2
Yes I tried mazda6 n 3 and they are the same like protoform body:)
Originally Posted by maskedrider
But the mazda6 body is slightly longer then the protoform madza6 by around half inch... wondering will it effect anythings?
hows the performance?? handling as good as phptoform ??
I have not used Blitz yet but I have used Kawahara which also uses thicker lexan. The main advantage I have found is body life is longer. Thicker bodies are heavier but not significantly so. Your car will turn in similar lap times. I also did not rip any Kawahara bodies in accidents. It has happened, once, with a 300m PF body. Basically, the left side was torn right off.
On the flip side, if you are skillful, bodies last a little longer anyway. PF is also cheaper than most brands and has a good collection of stickers. The biggest weakness of all bodies is their rear wing. If it gets deformed or busted, the body's aerodynamics are nuked. Thicker lexan hasn't been a big factor in preventing premature wing damage. All in all, the best way to determine 'best body' is to try it. Rob |
just ran a race with the blitz 3. i used a pritty beat up protoform body to measure it against, but it turned itthe same, if not better than the proto 6
the blitz 3 is very strong, and handles very well. i'd recommend it. my body weighed 155grams with paint, and wing mounted with 3 screws and large conical washers. |
Well all body are the same and will depend on your set up. |
i find although the body is heavier, it last alot longer than the proto bodies. and also nowaday the touring chassis is so light, sometimes u need to add more weight to the chassis.
I have blitz and protoform bodies. AFAIK, protoform bodies are thicker lexan than blitz :confused:
I have the Mazda 3. It's not as flexible as Protoform but it handles great. The only problem is that it crack easily when there is no bumper (crack easily on the rear because there's no bumper on the chassis in the rear.)
I've tried the Mazda 6 and the Stratus from Blitz while I was in Taiwan. I like the Mazda 6 the best. Its handling is in between the Protoform Mazda 6 and the Protoform Stratus 3.1
