Recomendations on a good reciver pack?
Iam running a MX-3S with a novak xxtra on a Yoke GT-4. Anyone got any good recomendations on good reciver pack?
The skyline 1400 mah 5 cell flat pack will fit right in and give your plenty of run time.
check out the prices at promatch. they have gp1100 receiver packs.
thanks for the input, iam looking at these reciver packs and it seems liek they are made from sub-c cells that are used to power electric rc's. Am i correct? If so cant I just make my own pack? Get 5 cells, soem battery bars, shrink and what not, and make a pack? Even if i get liek unmatched 3000 wound that gimme killer runtime?
Ahh ic, so they arent sub-C cells. Will sub-C cells work tho? Iam thinking this is the best option. 5, say unmatched 3000's, sub-c, made into a side by side pack, with a connector for my reciver. That way i can peak charge them and discharge and what not. What does every1 think?
the biggest issue will be if they fit on the chassis, and then they are going to be a lot heavier than a normal rx pack , so id just stick w/ something like ib 1200's, or something along those lines.
ahhh alright, i didnt think about most of the issues. I guess ill just buy a reciver pack from ebay or sumthing. Thanks every1
Yeah thats going to be very heavy , not worth the runtime....youll just have a sloppier , slower car with more roll and probably will be off-balance due to a bunch of weight being added to one point.
Normally they design the car for a certain battery and off-set all the main components to distribute the weight load evenly around the car. So when you change something like that youll probably have to dump a bunch more weight somewhere else to make it equal out , thus adding a good 150-200 grams to the car just for longer run time...in which your car will be much slower.
Ya makes sense, thanks again.
