Kyosho FW-05RR Forum
#106
Moderator
the R came wiht a fiber glass top plate, the RR came with a CF top plate.
#108
Moderator
Yeh the car uses a flat pack and yes foams.
#110
Moderator
most important would be the hardened ring gears for the diffs. The Ti pivot balls and Ti hinge pins are a close second. Then if the cars lacking them CV/Univ shafts for the front.
#112
Moderator
well it comes with both a gear diff and a front one way. On MOST tracks you will use the gear diff, only very high bite tracks would you use the one way
#115
Moderator
Originally Posted by macnkitty2002
are you saying that it comes with both a gear diff and a front one way just for the front? what comes in the rear, gear also?
#117
Moderator
few based on its right side exhaust. THS and Skyline have pipes. Kyosho also has a handful of them. The Skyline is the best.
#119
Moderator
Yeh, but way expensive
