Which Lipo for MRX5?
Hey guys, I just burned up a lipo this weekend and I need to order a new one. I already disposed of it so I cant just order another of the same so I need some ideas of what other batteries fit. I either need dimensions or what battery you run that I can still get. lipo only please.
Thank you,
Kyle
Thank you,
Kyle
The batteryspace is made to fit a 5 cell 2/3A NiMh batterypack. These cells have the dimensions of 17mm in diameter and 28mm long.
A total pack with solder tabs and shrink wrap will be about 85mm x 18mm x 30mm maximum.
Those are kind of the dimensions that I went off of. I ordered 2 battery packs for the car and I should be set. I ordered them a little long but I"m sure they will still fit due to the other two dimensions being either the same or smaller than the Nimh pack. Thank you!
