Old 12-16-2005, 12:12 AM   #1
acutts's Avatar
Default Charging receiver packs??
I was wondering if a Much More CTX charger would charge the receiver pack in my Serpent 950r?? The wall TX/RX charger doesn't work for some reason so wondering if this would?
acutts is offline   Reply With Quote
Old 12-18-2005, 06:54 AM   #2
fritzD's Avatar
Send a message via Yahoo to fritzD
i think it'll work... i use my pulsar to charge my receiver packs..
fritzD is offline   Reply With Quote
Old 12-18-2005, 10:58 AM   #3
onnetz's Avatar
just dont charge at over 1 amp..
onnetz is offline   Reply With Quote
Old 12-18-2005, 11:12 AM   #4
Trader Rating: 15 (100%+)
What is everyone charging the newer 1400Mh packs at. I use to charge the old 800Mh packs at one amp and they would take 45 minutes to charge. The new packs will end up taking over one hour. But I guess that it should take the same amount of time because I will still be using the same amount of power out of it before I charge for the main.
THE DOCTOR is offline   Reply With Quote
Old 12-18-2005, 12:25 PM   #5
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
I think my venom racing battery which was 1200mah had instructions included with it which said to be charged at 1.2 amps. 2 amp for fast charge but even said it would diminish its life.
I think the rule is. For every 100 mah you charge .1 amp. So 1400mah can take 1.4 amp.
At least thats how I believe Ive seen it.
Take care.
Artificial-I is offline   Reply With Quote
Old 12-18-2005, 03:38 PM   #6
GrandeGixxer's Avatar
I have always charged my reciever packs at 2 amps. My MTX-3 pack lasted longer than the car.
GrandeGixxer is offline   Reply With Quote
Old 12-18-2005, 04:52 PM   #7
miniracer's Avatar
I dont use my CTX to charge rx and tx packs. The CTX tends to be too sensitive that it false peaks often, you will have to raise the peak detect but that tends to heat up the pack too much . I use my pulsar to charge rx and tx packs at 1amp.
miniracer is offline   Reply With Quote
charging help 6 cell packs fordman86 Electric Off-Road 10 09-22-2006 04:05 PM
charging 1/12th scale receiver packs ixlr8nz Electric On-Road 2 04-10-2006 03:01 PM
Charging assembled packs Khan48 Rookie Zone 5 10-26-2005 07:16 PM
Charging receiver packs, making the connection Cain Electric Off-Road 1 08-09-2005 02:10 PM
charging reciever packs gasnewb!!!! Electric Off-Road 11 07-20-2004 09:24 PM
SEO by vBSEO 3.5.0
