Old 12-06-2005, 08:37 PM   #16
quantum's Avatar
Default recording info ?
does anyone know if the telemetry module can record the data, or if can only be viewed in real time?
if i could dump the data to a laptop after each run, really valuable information can be gathered and analyzed.
just think - you could compare the temperature of the motor against run time, and adjust gearing or driving lines. same with rpm vs motor temp. i would buy it for sure. but if its real time only, then i think its more valuable for nitro racers pit crews, less for electric
quantum is offline   Reply With Quote
Old 12-06-2005, 10:43 PM   #17
asw7576's Avatar
Originally Posted by Lou Decruss
the spektrum is not fcc approved..as it stands.
read here
OMG, you again ??
I don't care if spektrum is not FAA / FCC / FDA / USDA / CIA / FEMA / ATF / NASA approved, I'm still going to buy it !!
Old 12-07-2005, 07:15 PM   #18
Originally Posted by ira
I'm talking about the Nomadio unit, not the Spektrum.
sorry, my bad ! I guess you won't be adding this unit to your racing adventures.
rc racing dude is offline   Reply With Quote
Old 12-08-2005, 05:50 AM   #19
ira's Avatar
Trader Rating: 18 (100%+)
I think it is a good piece, hoooooo knows I just may try one. Kurt needs to do something with his hands anyway
ira is offline   Reply With Quote
Old 12-08-2005, 08:35 AM   #20
Uneke's Avatar
Send a message via AIM to Uneke Send a message via Yahoo to Uneke
Thumbs up
I think this is going to be a great device if it works properly. I think it will benefit nitro more than electric though.
Most nitro cars are under weight anyway. Whats a better way to get up to weight than with something useful instead of lead weight?
Uneke is offline   Reply With Quote
Old 02-28-2006, 04:57 PM   #21
Lou Decruss's Avatar
I hear Nomadio is going to have a program that lets the Sensor talk to spektrum receivers
LOW / SLOW mode LOW as in they have to go to low power by a FACTOR OF 6, slow because we have to go from 100Hz to 50Hz
Lou Decruss is offline   Reply With Quote
Old 03-01-2006, 05:42 AM   #22
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Source to that statement please.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 03-01-2006, 05:56 AM   #23
That may be true, but in order to use a Nomadio you have to be able to look past the tyco feel of the transmitter and the look of something cobbled together as an engineering prototype. It does not have the feel or look of a finished product. I for one am not going to blow another 500 dollars on one until they fix the feel and look of the device, and the size of the rx, it is bad enough to try and cram a KO RX into some of the TC chassis as it is. Put the nomadio rx in the mix and you can just about forget having the rx mounted low.
mguebert69 is offline   Reply With Quote
Old 03-01-2006, 08:38 AM   #24
i bought this telemetrey set up about a month ago, and its not all its cracked up to be, the one feature i wanted was the spedometer to help with gear changes and it cant keep up, the only way to use it is that it will record top speed. the temp readings are a little off also.
prossi is offline   Reply With Quote
Real Time Tray Dougnuts55 R/C Items: Wanted to Buy 4 01-19-2004 01:47 PM
Trinity Real time 2 dyaz21 R/C Items: For Sale/Trade 0 08-27-2003 07:39 PM
Real Time 2 users.... lonestar1127 Electric On-Road 8 02-15-2003 07:29 PM
REal tiMe 2 userS... lonestar1127 Singapore R/C Racers 4 02-14-2003 06:19 PM
Trinity Real Time 2 Cole Trickle Electric On-Road 1 11-21-2001 03:53 AM
SEO by vBSEO 3.5.0
