Team Magic G4
#9646
Maybe give a try and dial out some exponential on your radio or reduce throttle speed.
#9647
car setup is also important. diff oils and most important, throttle Finger.
a clutch wont be effective if just grabbing the throttle. ease it on then the clutch will function smoothly rather than just on.
the black spring is hard, and i tightened to just see 1 thread . so not alot of preload on the spring, the no weights in the shoes make it lighter, so yes it will engage later, but also with out weight behind it. so it wont be as snappy.
hard spring and light weights. then adjust the spring as required. low traction 10K diff oil , and the rest is roll centers and springs. good luck.
btw, how much harder is the black spring compared with the yellow spring? (since both are 1.8mm)
#9648
Black spring just works beter and doesnt get coil bind like the yellow one.
Better yet is just get a Mugen super hard or JP hard spring.
They work much better and dont bend/tweek to oneside like the TM1.8 black spring.
#9649
my resolution was to taper the flyouts in the center enough so there was sufficient gap between the flyout shoes and the retainer insert. i never had a clutch shoe wear bad after that and the clutch felt more consistent also. im guessing with the heat as well, the black spring would kink like Razzor said with the uneven preload on it from the flyout shoe.
#9650
what i actually found was that the retaining plate insert, that the spring sits on, actually interfered with the flyout shoes. so once they flew out, they didnt return all the way back. they went as far back as the insert would let them. since one side of the spring didnt actually touch the retainer plate as much, that flyout seemed to be the one that didnt return properly. this is what i found kinked the spring, and made the clutch shoe wear uneven.
let's see whether i can get my car to go faster!!!
#9651
any chance of having the part number for the mugen spring?
#9654
#9656
Mugen spring H0767
http://www.amainhobbies.com/product_...oducts_id/1909
or the JP Hard spring # 93519
#9657
Mugen spring H0767
#9659
#9660
Your only other way I would consider is through RCshopping.com they are usually prity consistant at taking 4 days to get the stuff to you.
Regards,
British Menace
