Team Magic G4
#7817
#7818
Hey Razzor, is all OK? Please phone me!
#7819
Dennis, hope you can make it one day to 301 raceway at MD.
http://www.301raceway.com
May have to be one or the other. Nats or 301??
Might not be able to make both but will try.
Need to talk to you concerning TMA banner too
Really like the 301 circuit though
British Menace
#7820
Well I should have it ready for the weekend.
im gonna be running this car at either
JACKSON R/C http://www.jacksonrcracing.com/onroadpics.htm
or
BLUE DIAMOND IN DELEWARE
or
Do you live in Jersey? Jackson RC is a real tight small track. I go there sometimes. I do some parking lot racing in Jersey City if your near and wanna get the bugs out before you go to a track.
lmk
#7821
no im in Pa right off the pa turnpike jackson is like an hour away i run elctric there they repaving it this week with tennis court smooth asphalt with no more curbs its gonna be awesome i would take u up on the parking lot shake down but im waiting on a pipe i have no pipe yet
#7822
Wow..........301 looks like a very cool track. Is this the place you were talking about us going to Dennis?
British Menace
British Menace
#7823
If you really wanna come down to Jersey City i can lend you a pipe..
#7826
#7828
Hi,
To get the feel you might be looking for, you can try running a softer rear spring. It does give the feeling of the rear just starting to come round when hard on the power (as the rear just starts to collapse, as its softer, but differnt to running a hard rear spring which will make the rear slide, but cause too much tyre wear) and it will give you a little more steering on power. It would probably be better with a stiffer rear roll bar than the standard G4S, either the G4+ type, or the Mugen type mod.
or, a stiffer rear diff, 20 or 30K would make a fair difference.
or, a lttle more caster angle, we find 1mm of caster makes quite a big difference to on power steering.....
You are right with the rear toe, with any set up there is a minimum rear toe required (which will vary !) so you need to find what you need from somewhere else.....
Hope that ll makes sense !
Good Luck.
Good Luck.
The car still seems to pull a little bit on the mid to out of a corner. I have 0 droop up front. I am thinking correctly by trying less travel? maybe 2mm?
Thanks for all the help..
#7830
