Team Magic G4
#6871
What did you guys put as not to have antenna touch the carbon fiber? I have a glitch and i beleive that is it.
#6872
#6873
good lookin out Tony on the screw's...i just placed an order...thank's...
#6874
Drill out the hole in the upper deck.
Feed the antenna through the fuel tube and place the fuel tube into the hole in the upper deck.
The antenna tube will fit nice and snug inside the fuel tube.
Did the trick for me.
Menace
#6875
What BM said works best.
#6876
quick change knuckle arm
eveybody G4S users!!!
anyone tried quick change knuckle arm on G4S?
i quess.. many setting was changed after quick change knuckle arm.
i tested it in korea circuit.. my car movement is very changed.
i also quess that i suffered after change quick change knuckle arm in FECMA..
#6877
I always put shrink tube anywhere that any wiring touches the carbon just to make sure there will be no shorts in the wiring anywhere.
#6878
Dont need as much camber as std rear hubs.That has been only thing i noticed.
#6879
the offset is different.. front and rear all!!
when width setup was same (front 197mm/rear 199mm)
quick release hubs make more understeer in corner-in...
and rear was uneasy in corner-out.
this is only my subjective feel.. (it maybe false)
so i will test tommorrow after some change.
front hub will be changed by Std hub.
rear hub will be used by quick release hubs.
But.. i will change rear wheel hub what is narrower than stock wheel hub(NT1's wheel hub).
then i quess offset will be same with Std hubs.
#6880
Regional Moderator
Well I went ahead and ordered my parts from rc-mushroom. Man do they have a lot of G4 stuff!
To top it off, even with the ems shipping, it will be cheaper than if I had been able to buy the parts from Trinity.
So all I can do now is hope that rc-mushroom is quality. I've never ordered from them before, so <fingers crossed> everything will go well.
#6881
I get everything shipped to Canada very quickly and he is also just a phone call away if you ever have any questions.
#6882
Regional Moderator
You really should check out Raceday Hobbies. Sam has every part in stock and ships out same or next day. And the best part is that he posts on this forum regularly under the name G4S'er. Check out his shop at http://www.racedayhobbies.com
Believe me, I would have loved to get them from Raceday, but I can't buy what they don't have.
#6884
I bought my stuffs from mushroom too. They will send it to your home.
#6885
Yes but have you seen the shipping they charge??!!!!
I was going to buy some bodies from them a month or so ago and I noticed at the last moment that they wanted $52 for shipping to the U.S ????
Menace
Menace
