Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-10-2006, 05:48 PM   #1501
MechanicJon's Avatar
Send a message via MSN to MechanicJon
Anyone have a diff side bearing out? If you do could you measure it with a set of calipers and post the size. Never mind, got it off Team Magic website.
Might be old news to some but check out http://www.avidrc.com/ for R/C bearings. $1.00 per bearing!!
12x18x4mm diff side bearings 4 required
6x12x4mm outer hub, 2 speed shaft and middle shaft 8 required
10x15x4mm inner hub bearings 4 required
5x10mm flanged side belt tensioner 2 required
5x10x4mm centex clutch bell 2 required
MechanicJon is offline   Reply With Quote
Old 07-10-2006, 06:13 PM   #1502
afm
afm's Avatar
Originally Posted by MechanicJon
Anyone have a diff side bearing out? If you do could you measure it with a set of calipers and post the size. Nevermind, got it off Team Magic website.
12 x 18 x 4 mm
AFM
afm is offline   Reply With Quote
Old 07-10-2006, 07:41 PM   #1503
Piyo Piyo's Avatar
Added :
2 pcs 6x10 mm bearings inside 2 speed housing.
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 07-10-2006, 08:02 PM   #1504
munrath's Avatar
Send a message via AIM to munrath
Dennis and Team - Thanks for the support!! The G4S managed to hold off all those Mugen's, VONE RR, and Serpents this past weekend during the first day of qualifing of the Region 2 race located at 301Raceway. The car was simply dialed and maintained great corner speed and I didn't have to worry about traction rolling. However on day 2 my good friend Vincent Jackson put in a very clean and fast run to bump me into 2nd. During the main I got a great start and then ran into motor problems and had to pull the car. All in all it was a great showing of the cars potential and many positive comments on it's performance.
Jorge and Bobby also ran the G4S this past weekend. It was great meeting you both and you guys did great!!
TIP for this past weekend:
The small stubs on the rear body mount do break off. I drilled mine out and put in a set screw to help hold them into position.
Thanks again for all the support!!
Mark
Mugen Seiki - Murnan Modified Motors - ParmaPSE - KO PROPO America - Maxy's Pro Racing Fuel - Twister Tires USA - Nexus Racing - Express Motorsports
munrath is offline   Reply With Quote
Old 07-10-2006, 09:03 PM   #1505
mtveten's Avatar
I am experiencing a problem with my front sway bar where if I push down on either rear corner the opposite front wheel will lift off the ground long before it reaches the droop setting. If I push in the middle of the rear or remove the front bars both front wheels stay down and the front will lift to its droop setting.
My droop settings are 3R and 0F with a ride height of 5.5R & 5F. Tires are 62mm rear & 60mm front.
Mark
mtveten is offline   Reply With Quote
Old 07-11-2006, 06:35 AM   #1506
rcrevolution's Avatar
Send a message via AIM to rcrevolution
are those shock ends in yet
rcrevolution is offline   Reply With Quote
Old 07-11-2006, 08:48 AM   #1507
mtveten's Avatar
I dunno if the shock ends are in yet but they do have crash kits and you are better off getting the kit with arms, bulkheads, & shock parts for under $50 than a part here & there at $6-8 each.
Mark
Old 07-11-2006, 01:25 PM   #1508
Car Breaker's Avatar
I need the Shock end too
Car Breaker is offline   Reply With Quote
Old 07-11-2006, 06:41 PM   #1509
impalabob64's Avatar
Send a message via AIM to impalabob64
Thumbs up Thank you Mark
Mark nice to meet you too man,awsome driving dude ,i wish i could hve done better ,but for the first on the track i did fairly well.The cars was sick fast with that Rev in huh thx for the setup help see you in Toledo.
TeamMagic G4RS 09,
Machinaria.com
MurnanModified Engines
Swiss Components
Twistertires
impalabob64 is offline   Reply With Quote
Old 07-11-2006, 07:33 PM   #1510
Regional Moderator
Darkseid's Avatar
Well another race day...
...another rain day.
We're setting a record for the worst outdoor racing season ever in this area. So I haven't been able to take my G4s back out since I found a great set up for it.
Hopefully I'll be able to race it again soon...with no rain.
Tamiya M05pro - Tamiya TA05 IFS R - Tamiya TB-03 - TRR(Team Ruining Racing) - Futaba 4PK - Core Creations - Yu-Gi-OH! TCG - WOW player - iMac - iPhone 3G
Old 07-11-2006, 08:12 PM   #1511
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
Anyone here play with the option K-Factory gears and pulley? m thinking of upgrading my stock plastic belt pulley to K-Factory hard coated ones, but m not sure which no. of teeth to get. so if anyone here already have upgraded their full sets of gears or pulley, mind letting me know pls? for example, the side pulley, 18T or 20T is good. so wat i m looking after for is the complete set that makes the car run fast, coz i heard that there is a way to calculate it, but i have no idea. thanks.
uniquexme is offline   Reply With Quote
Old 07-11-2006, 09:09 PM   #1512
Regional Moderator
daniz24's Avatar
Winner of DTM Cup in Indonesia
2005 - Daniz24 (G4 Evo)
2006 - Teddy Syach (G4S)
After finish line, we found out that the there's a leak from the pipe (1 of the small manifold spring is lost or broken) that's why after 2nd refuel the car suddenly lost its power for about 10% and sounds like its overheating
daniz24 is offline   Reply With Quote
Old 07-11-2006, 10:53 PM   #1513
asw7576's Avatar
Yup... Congratulations to Teddy Syach (G4S). He is awesome driver ... Just like Fernando Alonso.
On roads || Xray nt1 || Mugen Seiki mrx4-r, mtx4, mtx3 prospec || Tamiya msx, m03, m04 || Yokomo mr4tc-bd || Associate L4
Off roads || Xray xt8 || Hobao hyper8
Radio || Futaba 3pk & 3pks
Old 07-13-2006, 11:12 AM   #1514
Default Brian Berry's Set-up
uniquexme, try Brian Berry's set-up off the Team Magic web page.
Brian is a sponcored Team Magic driver.
as it changes rear roll center and works great check it out use 19 thooth brake pully and 20 tooth 2 speed shaft pully with larger rear tires I think it is 4mm difference.
A big plus is your not gringing down so much new foam.
Check it out it maybe what you are looking for.
Regards Mac
macthehack is offline   Reply With Quote
Old 07-13-2006, 05:28 PM   #1515
uniquexme's Avatar
Regards Mac
thanks bro, i shall check it out.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Forum Jump
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 01:00 AM
Team Magic G4s MaDaGAS CAR Australia For Sale/Trade 29 05-07-2007 02:30 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 04:51 AM
team magic g4 + elephant R/C Items: For Sale/Trade 4 04-26-2004 06:34 AM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 10:40 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
